Post by seandorothy on Jul 22, 2014 18:54:52 GMT -6
First time on here. I have a used new taotao 4 batteries. Not chargin w charger plug so we cut the 2wires red positive green neg so im told n tried chargin like that. Stil no luck.... engine turns over runs for 30 sec n dies.....help plez!!!
Post by Guitarman on Jul 22, 2014 20:55:46 GMT -6
Under the seat next to the battery box is a fuse box. Or should be if you have the bike I think you do... This one is pulled out and all the connections have been waterproofed with Red High Temp silicone.
Post by Bashan on Jul 22, 2014 21:50:49 GMT -6
First time on here. I have a used new taotao 4 batteries. Not chargin w charger plug so we cut the 2wires red positive green neg so im told n tried chargin like that. Stil no luck.... engine turns over runs for 30 sec n dies.....help plez!!! I'm sorry man, I read your post twice and I'm not getting what you're saying. How about slowing up a little? 4 batteries? At once? Used new? You cut the wires to help charge? Fill us in a little better and we'll see if we an help. Pix help too. Thanks, Rich
Post by Alleyoop on Jul 22, 2014 21:58:55 GMT -6
I think the OP means it is a TAO TAO 4 Wheeler and the battery is not charging. But do not understand about which RED POSITIVE WIRE AND GREEN GROUND WIRE was cut. Not a good idea to cut a RED POSITIVE RED WIRE that is a given and Cutting a Ground wire NOT a good move either. So since we are having a little problem with what was done, take a picture of what was cut. Alleyoop HERE IS HOW TO POST PICTURES USING THIS HOST. IT IS EASY AND FREE: 1. Click on this link: tinypic.com/index.php2. Click on Browse, that will link to your computer. 3. Find what you want to load. 3. Click on the name of the picture 4. Click on OPEN 5. Click on UPLOAD 6. Click on the LINK that starts with IMG. 7. RIGHT CLICK and CLICK on COPY 8. THEN Come here to your THREAD ON DOC. 9. RIGHT CLICK and CLICK ON PASTE.
Post by seandorothy on Jul 23, 2014 12:50:05 GMT -6
I got a used electric scooter that has 4 batterries all connected together.The charging port didnt work. So a friend cut the charging port that had a red wire n green wire. We tried chargig w a charger....the charger says it is fully charged. Exept when we run it it dies about 30 sec later....the batteries r not charging rite? Do i trycharge them individually? And id so im confused myself.the batteries r hooked up positive to neg neg to positive....was told it cycles as one? To me it looks wrong. Plez explain??? Dorothy
Post by seandorothy on Jul 23, 2014 12:54:36 GMT -6
I believe its the ate 501 taotao scooter....cant upload pics sorry....this is my project and am tired of this electrical prob already...can i just take all the batteries out n just put 1 bigger one?
Post by Alleyoop on Jul 23, 2014 13:28:38 GMT -6
Check each individual battery you may have bad batteries. They have to be hooked up to produce 48V to feed the electric motor. Here is how they should be hooked up to produce 48Vs. The charger is special it is a 48V charger to charge all 4 batteries at once so it may be a bad charger. If you using a regular charger then you need to charge up one at a time. A regular charger only handles 12v systems. Alleyoop
Post by jct842 on Jul 23, 2014 15:08:02 GMT -6
If the owner of the scooter does not have and know how to use a multimeter he might just as well stop right now. With out knowing What you are doing you are just guessing. The only way to get to your problem is to measure.
Did the scooter ever run? Batteries do go bad. Electronic speed controls also go bad. If they are lead acid a battery shop can test them. If they are other types they can be tested as well by some one that knows how to do it.
Post by Alleyoop on Jul 23, 2014 16:23:56 GMT -6
They are just 12v sealed batteries, my brother in law had a few electric bikes. The last one that actually hauled at 40mph he just sold it. It was a 48V system (4 12v batteries, like the OP apparently has). And it is a no brainer, it is not rocket science. If you do not have a multi meter go to harbor freight get a 6.00 dollar multi meter and set it on DC and touch the POSITIVE POST with the RED LEAD and the NEGATIVE POST with the BLACK LEAD and that is all that is to it to check a batteries voltage. They come with instructions for testing different things and what to set the meter to. Alleyoop www.harborfreight.com/catalogsearch/result?q=volt+meter
Post by Guitarman on Jul 23, 2014 18:54:18 GMT -6
Just noticed I posted that pic on the wrong thread... LOL
