Post by robertban on Sept 26, 2014 22:51:53 GMT -6
Post by Bashan on Sept 26, 2014 23:43:23 GMT -6
Not to worry Robert, I have this engine albeit on a different scooter. You should read this over. This is how the canister shakes out:
So yes, in answer to your first picture, the purge line from the vapor canister goes to the airbox so the nasty gas fumes are used up. You must not have any open ports on the airbox or vac lines.
Yes, that hose probably goes there. It is an accumulator for oil vapors. It cannot remain open as it produces a vacuum imbalance when it is left open.:
In answer to the above pic, it goes to the airbox.
