Post by offutt0311 on Oct 1, 2014 19:44:00 GMT -6
Also on a side note, got a tracking number for YRC tonight....thank god
Post by Alleyoop on Oct 1, 2014 20:12:25 GMT -6
FANTASTIC!! Good to hear it is on it way. As for jets and filter try he sells single jets and or a pack of 4. www.buggypartsnw.com/
Post by offutt0311 on Oct 2, 2014 7:12:59 GMT -6
FANTASTIC!! Good to hear it is on it way. As for jets and filter try he sells single jets and or a pack of 4. www.buggypartsnw.com/Hey Alley. Thanks again. I went ahead and ordered his stage 1 kit. It's the uni filter, 4 inch velocity stack that bolts in stock position, and it comes with a 125 and 130 main jet. Said those were the two reccomended for that setup. Which I'll have a hot plug, cdi, and coil. If it turns out to be too much fuel, I'll order some jets. Like you said, they're cheap enough lol.
Post by Alleyoop on Oct 2, 2014 10:07:47 GMT -6
Here is my setup: Alleyoop
Post by offutt0311 on Oct 2, 2014 11:06:13 GMT -6
Here is my setup: Alleyoop Yea that pretty much looks like what I bought, except mine has a UNI. What main jet are you running?
Post by Alleyoop on Oct 2, 2014 11:41:55 GMT -6
Main Jet is 122.5 and a 38 pilot jet but my motor is bored out It has a 62mm BBK and a 60mm Stroker Crank went from 149.6cc's to 182cc's. Got to tell you I have a Kick arse trike even KING KONG can't catch me Alleyoop Here is are all the mods on my Trike: 62mm BBK 60mm Stroker Crank Primary is 43 teeth 16/37 Hoca Tranny Gears – Original were 13/40 K&N Air Filter with a Short Stack SuperTrapp Muffler 1 1/4 Header Pipe 24mm Carb #122.5 Main Jet #38 Pilot Jet Peformance Coil/CDI NCY Performance Clutch&Bell Manual Choke Iridium Plug Koso Variator 12g Dr. Pulley Sliders 205/65-10 Kenda Load Tires-3"s taller than OEM 29 tooth Drive Sprocket-came with 24 tooth. DID 428 Pro V Series O-Ring Chain Givia 29" tall Windshield All Led bulbs Except the Headlights-I do not drive at night 4 way Flasher Turn Signal Beeper Relay for the Beeper connected to the Brakes VIP Trunk with Led lights Brake light Flasher on the Trunk Wing Radio with Remote, SD card,MP3 connections Alleyoop
