Cutting out
by: rogerowen - Sept 29, 2014 12:21:07 GMT -6
Post by rogerowen on Sept 29, 2014 12:21:07 GMT -6
My MBK Mach G 50 AC (AKA Yamaha Jog) had been sitting for a year or so, and wouldn't run due to flooding. I cleaned the carb and it ran better but would just die as I was riding along - never stopped completely, cut out for a bit then ran again for a while - then cut again..... and so on. I fitted new plug, plug cap, coil and lead and no difference. Oil tank is going down, and I've also poped some oil into the fuel for good measure. Anyone have any ideas what could be causing this cutting out?
Post by jct842 on Sept 29, 2014 14:02:48 GMT -6
Gummed up carb, did you take completely apart and see that ALL the passages are clear?
Cutting out
by: rogerowen - Sept 30, 2014 10:41:57 GMT -6
Post by rogerowen on Sept 30, 2014 10:41:57 GMT -6
Gave the carb a pretty good clean, and blow through with compressed air. Float seemed to be working ok. Idle screw seem to need to be a long way out to stop the engine from racing at throttle off. A little bit of petrol coming up from cable entrance on carb top. Runs ok for a bit, then starts to cut. Struggles on hills, and often stalls at tick over - just like as if the ignition turned off. Sometimes it goes to stall but picks up again. All very frustrating!
Cutting out
by: Alleyoop - Sept 30, 2014 11:11:39 GMT -6
Post by Alleyoop on Sept 30, 2014 11:11:39 GMT -6
It is getting to much fuel if fuel is coming out of the top by the throttle cable. Turn the AIR SCREW 1/4 turn COUNTER CLOCKWISE, that is the SCREW near the AIR FILTER SIDE the one in the middle is your IDLE SPEED SCREW. Alleyoop
Cutting out
by: Guitarman - Sept 30, 2014 15:20:36 GMT -6
Post by Guitarman on Sept 30, 2014 15:20:36 GMT -6
Also, since it sat for so long, you should drain and clean the tank. It's likely got a lot of crud sitting in there that could be clogging you up as well.
Post by cyborg on Sept 30, 2014 15:28:06 GMT -6
yes i agree with guitar and Alley,,,change the gas and give the tank a good cleaning,,,and back off on the fuel delivery
Cutting out
by: Alleyoop - Sept 30, 2014 16:32:35 GMT -6
Post by Alleyoop on Sept 30, 2014 16:32:35 GMT -6
Be Careful who you take advice from some folks on here will tell you to use this method to adjust your carb. Alleyoop
Post by jct842 on Sept 30, 2014 17:14:50 GMT -6
Would that werk with EFI?
Post by jct842 on Sept 30, 2014 17:15:06 GMT -6
Fix the screwing edit9
Cutting out
by: richardv - Sept 30, 2014 18:21:08 GMT -6
Post by richardv on Sept 30, 2014 18:21:08 GMT -6
Alley that is hilarious. Thanks I needed a laugh tonight.
Cutting out
by: cyborg - Sept 30, 2014 20:51:16 GMT -6
via mobile
Post by cyborg on Sept 30, 2014 20:51:16 GMT -6
Kinda looks like Luke ,,, that's creepy
Post by rogerowen on Oct 1, 2014 9:34:09 GMT -6
Thanks guys, I'll drain and clean the tank and the carb again and report back if it works.
