Post by Alleyoop on Oct 12, 2014 14:17:24 GMT -6
Well that attemped jumnp turned the motor WAY FASTER than any scooter battery will. So that points to some other problem NO SPARK, NO GAS, CDI GROUNDED OUT, BAD COIL, BAD CDI, BAD PICKUP COIL, BAD STATOR etc.. Since it turned over so fast TAKE THE PLUG OUT and see if it is wet or dry, I did not hear it fire ONCE so I would expect the plug to be WET. If DRY then fuel delivery problem is my 1st suspect/ Alleyoop
Post by heruk on Oct 12, 2014 14:20:34 GMT -6
pff didnt start but it was like just at the threshold of starting.... like right screwing there
Post by heruk on Oct 12, 2014 14:21:28 GMT -6
@alleypoop yea i took it out the plug was wet
Post by Alleyoop on Oct 12, 2014 14:27:27 GMT -6
OK That points to the PLUG NOT FIRING which I did not hear once when you jumped it.
Do you have a GROUND WIRE FROM MOTOR TO THE FRAME? Alleyoop
Post by Bashan on Oct 12, 2014 14:34:24 GMT -6
ah gehen Sie bitte Ihre Windel Ich werde es in den Hut zu entsorgen.
Post by heruk on Oct 12, 2014 14:35:27 GMT -6
OK That points to the PLUG NOT FIRING which I did not hear once when you jumped it. Do you have a GROUND WIRE FROM MOTOR TO THE FRAME? Alleyoop Yea its grounded and secured well. Hmm not firing? i saw spark when i tested it though it was kinda dim but it was in full sunlight so... hmm
Post by heruk on Oct 12, 2014 14:36:28 GMT -6
ah gehen Sie bitte Ihre Windel Ich werde es in den Hut zu entsorgen.LOL strange fruit in this forum haha
Post by Bashan on Oct 12, 2014 14:37:45 GMT -6
Yeah, he says he has a ground wire. Test the red/black from the stator and see what kind of voltage you get off of it. Set the multi for AC and put one probe in the wire connector. Ground the other probe and tell us what you get.
Post by Alleyoop on Oct 12, 2014 15:10:51 GMT -6
Post by Guitarman on Oct 12, 2014 16:57:39 GMT -6
Besser nicht sein in meinen Hut Sie Collabrators! Lass mich die Gestapo zu nennen. Fricken punks.... Remind me of the Vichy French. BLEH! Vie La OHO LA LA! HEY JR! I keep getting error codes when I post something. Error 32 is the latest. "Can't post to this key"
Post by Bashan on Oct 12, 2014 17:39:57 GMT -6
Error 32 means Gman is trying to post. It is a code specific for you Andy. Out of the millions of people on Proboards you are the only one with your own error code. I will swing the chicken and alert the Jackknife.
Oh JAAAAAACCCKKK!!!
Post by Guitarman on Oct 12, 2014 17:49:48 GMT -6
Y'know Rich.....
That Avatar is far far more scary than mine. Kinda reminds me of the guy in the Whitehouse right now... And THAT brother, is SCARY.
Post by Guitarman on Oct 12, 2014 17:50:46 GMT -6
Error 32 means Gman is trying to post. It is a code specific for you Andy. Out of the millions of people on Proboards you are the only one with your own error code. I will swing the chicken and alert the Jackknife. I always knew I was special. *drool*
Post by jct842 on Oct 12, 2014 20:07:57 GMT -6
I get that error code too. There is going to come a time when all the neat sh!t added here is going to cause this board to self distruct. I belong to another proboard forum with a different name and a different subject and with no bells and whistles that loads faster, no errorcodes, no nag windows and works as proboard intended.
Post by heruk on Oct 17, 2014 12:04:36 GMT -6
Yeah, he says he has a ground wire. Test the red/black from the stator and see what kind of voltage you get off of it. Set the multi for AC and put one probe in the wire connector. Ground the other probe and tell us what you get. what voltage should i set the multi meter to?
