Post by Deleted on Nov 19, 2014 12:07:57 GMT -6
Hey Guys, I almost hated to post this one but I looked through the Vacuum routing pics and I couldn't see where the Crankcase vent nipple/hose should be connected to? I do not have all that extra piping with canisters and such. I got 1 tee already in there where it comes off of the intake to the T and another Vac line from the carb to that T and then to the fuel regulator. Thanks Scooter Team #1 Born
2008 Chuanl LB150T-12 GY6 LB1P57 QMJ
Post by jct842 on Nov 19, 2014 12:12:18 GMT -6
What scooter are you working on?
Post by Deleted on Nov 19, 2014 12:16:24 GMT -6
jUST ADDED IT sORRY dOC!
Post by Bashan on Nov 19, 2014 12:41:15 GMT -6
The crankcase doesn't have a vacuum line. It has a breather hose. Often they will run to the air cleaner where the vapors are drawn off as a pollution measure. They usually come off the valve cover but sometimes the right side of the crankcase. Sometimes the spot where they hook on to the air cleaner is plugged and they just stick a filter in and tie it off high:
