Post by cyborg on Dec 1, 2014 8:47:55 GMT -6
That is odd ,, I would have thought they would have sorted the fuel issue out by now,,, maybe your just getting NOS of the needles and not the viton rubber tipped ones
Post by jct842 on Dec 1, 2014 10:36:21 GMT -6
The only way to ensure a 4 or under kick engine start ( with choke when cold) is to turn the fuel tap off once I shut the engine down. If I don't the engine gets flooded and a small puddle of fuel/oil is usually under the engine. That is the reason all scooter/motor cycle engines that have gravity fuel feed have a shut off valve. even my farm tractor has one. They need to be off when engine is off. If the float valve sticks you can have a fire, a crank case full of fuel, and a host of other problems.
Post by jct842 on Dec 1, 2014 10:45:35 GMT -6
You do realize your carb needs to come apart and get repaired don't you?
Post by cyborg on Dec 1, 2014 13:49:06 GMT -6
As far as ridin in below 30 degrees,,,,BBBBRRRRR is right,,,i folded up my tent long before that,,,they don't call me P U S S Y B O Y for nuthin
Vespa Specialist
Post by Kaveman on Dec 3, 2014 11:57:26 GMT -6
I am more than aware of dealing with the carb. Last year I replaced the entire float mechanism after rebuilding the si 24/24. I also do use the fuel cutoff valve ( when I remember to do so). willc.
