Alleyoop
by: hobbles - Jan 9, 2015 5:37:39 GMT -6
Post by hobbles on Jan 9, 2015 5:37:39 GMT -6
Mornin Alleyoop, What is that box called that is on the back of your trike? Wouldn't that work as a back rest for a passenger?? Would that bolt onto our trike???
Alleyoop
by: Alleyoop - Jan 9, 2015 12:33:48 GMT -6
Post by Alleyoop on Jan 9, 2015 12:33:48 GMT -6
Those are called Trunks to carry stuff. And yes they also act as a backrest for passengers, they have padded backrests that you put on the trunk for the passenger. You can get them in many sizes, some with lights like mine, mine has turn signals and stop lights and running lights, the more lights in back the better I say so the cars can see you better and when your stopping and or turning. Alleyoop
Alleyoop
by: hobbles - Jan 9, 2015 13:07:21 GMT -6
Post by hobbles on Jan 9, 2015 13:07:21 GMT -6
Alleyoop
by: jct842 - Jan 9, 2015 13:57:03 GMT -6
Post by jct842 on Jan 9, 2015 13:57:03 GMT -6
no lights and the real cheap ones tend to vibrate and crack. reflectors don't work during the day if you are looking for safety.
Alleyoop
by: Alleyoop - Jan 9, 2015 14:06:06 GMT -6
Post by Alleyoop on Jan 9, 2015 14:06:06 GMT -6
On his Trike there is not much rail mounts in the back to mount a trunk. Here you can see HIS trike they have an extension to mount the trunk. Now the Trunk CAN be mounted on the back rail by drilling some mounting holes but depending on the passenger if he or she is wide bodied will not have enough room back there. Alleyoop Yours does not have a rail system like this to easly mount a trunk.
Alleyoop
by: hobbles - Jan 9, 2015 14:43:30 GMT -6
Post by hobbles on Jan 9, 2015 14:43:30 GMT -6
See Boys, that's why I asked on here. I find out all I'm gonna need to know before I spend the money. The Wife is a lil thing, darn near 5' tall and 125lbs. This is what I have to work with on the trike. All ideas and thoughts are welcome/needed. 1. 2. 3. 4.
Alleyoop
by: Alleyoop - Jan 9, 2015 15:23:32 GMT -6
Post by Alleyoop on Jan 9, 2015 15:23:32 GMT -6
Since under there is metal and it is also holding the seat you can get two pieces of flat iron and bolt them to the two holding the seat and make your own extension.
Or you use those two bolts holding the seat and mount the trunk and see if the wife will fit. After seeing your wife I think she will fit without an extension but to make sure bolt the trunk down using the two bolts holding the seat and have you and her sit on it. Alleyoop
P.S You have a very nice spread there Hobbs and some very nice places to ride I can see those ATVs come in very handy and are a lot of fun.
Alleyoop
by: cyborg - Jan 9, 2015 16:14:18 GMT -6
Post by cyborg on Jan 9, 2015 16:14:18 GMT -6
Ah nothin like a little size 4 on the back,,,,,the bike doesn't even know she's on there
Alleyoop
by: hobbles - Jan 9, 2015 17:17:26 GMT -6
Post by hobbles on Jan 9, 2015 17:17:26 GMT -6
Thanks Boys, I think I will order one and make it fit. The ATV sure does come in handy for hunting and getting fire wood.
Alleyoop
by: hobbles - Jan 9, 2015 17:42:57 GMT -6
Post by hobbles on Jan 9, 2015 17:42:57 GMT -6
I'm trying to find that extension for the trunk now.
Alleyoop
by: Alleyoop - Jan 9, 2015 19:24:58 GMT -6
Post by Alleyoop on Jan 9, 2015 19:24:58 GMT -6
Well you can find something that you can modify or get a hold of RAPIDREPAIR(JIM) he can order that mount for you from IceBear. Alleyoop I could not find the mount but I did find How you mount it on your trike that the seat is actually attached to so the Seat can rotate back without the Trunk going with it.
Alleyoop
by: hobbles - Jan 10, 2015 3:37:36 GMT -6
Post by hobbles on Jan 10, 2015 3:37:36 GMT -6
Thanks Alleyoop, I sent him an e-mail.
Alleyoop
by: hobbles - Jan 10, 2015 10:48:57 GMT -6
Post by hobbles on Jan 10, 2015 10:48:57 GMT -6
How do I find out what model ours is? I can read the vin number. All it says next to "Type" is motorcycle.
Alleyoop
by: Alleyoop - Jan 10, 2015 11:16:09 GMT -6
Post by Alleyoop on Jan 10, 2015 11:16:09 GMT -6
Alleyoop
by: hobbles - Jan 10, 2015 11:42:49 GMT -6
Post by hobbles on Jan 10, 2015 11:42:49 GMT -6
Thanks
