Post by dmartin95 on Jan 21, 2015 8:04:09 GMT -6
I surf a lot of scooter part stores, but one item I haven't seem to come across yet is a really good gasket set...
I could care less about cost, I'm looking for the highest quality gaskets one can get... Anyone have links or opinions?
Also, what about gasket sealant? I've seen a few sources say use NONE, but I haven't seen anything that recommends using a sealant. In fact, every GY6 breakdown and rebuild Video I've seen, when they crack the case, it only looks like the gasket was in there with no sealant.
Because this is an aluminum block, copper gasket spray will help conduct/distribute the heat, but what about other spots like the crank halves?
Post by cyborg on Jan 21, 2015 8:54:30 GMT -6
I use a lite coat of copper spray,,, never had a leak,,,
Post by dmartin95 on Jan 21, 2015 16:28:05 GMT -6
I spent a lot of time searching today and most of the "performance types" of gaskets sets are only performance because they're for BBK's and mods... I have came across some that look higher quality than others like in the following pics, but I can't seem to locate an entire set... And, to top it off, looks could be deceiving.... What do you all think would be the better gasket based on the pics 1 or 2? PIC 1: PIC 2:
Post by cyborg on Jan 21, 2015 18:42:43 GMT -6
I'll take door #1 wink
Post by Bashan on Jan 21, 2015 20:26:15 GMT -6
Yeah, the one on the left. I got my last gaskets from Mike at BPNW and they were like the ones on the left....worked great. They are the bi-metal ones with the copper rings on them. Now, as far as sealant, the theory is that it actually expands the tolerances especially on the tower. Also, sealant on the case halves supposedly makes for a poor union with the crank because it holds the case apart. I've never had any trouble using copper sealant and red RTV but who knows? It's what I've read. Rich
Post by jct842 on Jan 22, 2015 10:07:16 GMT -6
I had never used copper spray before doing the top end of the majesty. Local auto parts guysold me on getting a can with a dauber in it....costs less. I am satisfied with it, no complaints
Post by clonedrone on Jan 22, 2015 15:03:50 GMT -6
Try my fine friends at Cometic gasket. 800/752-9850 Ohio based company. Very high end, choices of materials and thickness. Nice for setting up the top end at Zero Deck. Wip up customs in a day or two.
Post by cyborg on Jan 22, 2015 16:39:55 GMT -6
OOOOO thanks Clone i didn't know they did customs,,,,i have used cometic on many a build,,,nice stuff
Post by Alleyoop on Jan 22, 2015 17:05:47 GMT -6
I can see coughing up the cost for a set of gaskets for a 5,000+ racing motor but not on a 300.00 dollar motor..LOL Big overkill if you ask me and won't buy you anything over a good set of chino gaskets. Alleyoop
Post by clonedrone on Jan 22, 2015 17:10:58 GMT -6
I can see coughing up the cost for a set of gaskets for a 5,000+ racing motor but not on a 300.00 dollar motor..LOL Big overkill if you ask me and won't buy you anything over a good set of chino gaskets. Alleyoop I had them make me custom head and three different thickness of base gasket for under $12. bucks. Stuck them in the mail for cheap shipping for me. Just a different option. figured as much
Post by dmartin95 on Jan 22, 2015 17:18:25 GMT -6
Try my fine friends at Cometic gasket. 800/752-9850 Ohio based company. Very high end, choices of materials and thickness. Nice for setting up the top end at Zero Deck. Wip up customs in a day or two. Awesome link! Thanks for sharing
Post by Alleyoop on Jan 22, 2015 17:18:48 GMT -6
Who did you talk to Frank over there?
Post by clonedrone on Jan 22, 2015 18:43:23 GMT -6
Who did you talk to Frank over there? Me? S. Neely, J,Moses or Spot the owner I worked with them in the past
Administrator
Post by JR on Jan 22, 2015 21:12:55 GMT -6
Did someone say sealant? Well if you want to really stick it together, man up and use this crap!
And if you're in the mood to take something apart with a hammer and chisel use this old time favorite!
And yes I still have some of this crap too!
Post by cyborg on Jan 22, 2015 22:03:46 GMT -6
Jesus where did you get those relics Jr.?,,,I think Moses used that one in the first pic,,,,probably get a good buck for both on ebay
