Post by rwima on Feb 22, 2015 0:55:48 GMT -6
HI everyone How I can connect the fan with the sensor, there are two sensors. The first in the carburetor and the second in the Radiater and has two exits So which sensor is responsible for the fan ؟ & HOW I CAN connect it with The fan ?
Post by cyborg on Feb 22, 2015 8:17:44 GMT -6
The radiator sensor is the one you need ,,, it is in fact a temperature switch that gets fed a hot wire and the other " open" end goes to the fan so when the switch closes because of heat it sends power to the fan
Post by rwima on Feb 22, 2015 21:48:06 GMT -6
Thank you, my dear brother connect the sensor to negative pole such a picture?
Post by cyborg on Feb 22, 2015 22:13:09 GMT -6
I would think it's the other way around ,,, positive hot to switch ,,, when switch turns on power to fan,,, fan to earth( ground),,,,,, positive earth thought died with the English years ago thank goodness
Post by rwima on Feb 22, 2015 23:53:00 GMT -6
OK ground)
Post by rwima on Feb 23, 2015 0:03:22 GMT -6
SO What IS THE JOP OF Carburetor SENSOR WITH 1 WIRE ?
Post by cyborg on Feb 23, 2015 0:11:19 GMT -6
Could be a heater for the carb
Post by rwima on Feb 23, 2015 2:41:00 GMT -6
it is not A ELECTRIC CHOKE it is sensor with 1 wrie
Post by Guitarman on Feb 23, 2015 4:20:37 GMT -6
Lets have a picture of it then.
Post by rwima on Feb 23, 2015 22:40:20 GMT -6
Thank you for your replies This is located in the yellow circle
Post by cyborg on Feb 24, 2015 9:15:17 GMT -6
I'm getting no pic
Post by jct842 on Feb 24, 2015 10:02:35 GMT -6
I would sure like to see a heat sensor located in the head of the engine. As I remember that's where the one is for my majesty. The thermostat is up there too. I never bothered to check where the sensor is on my riva as a previous owner had wired the fan to stay on all the time, it comes on with the key.
Post by Bashan on Feb 25, 2015 1:01:05 GMT -6
The other sensor is for your heat gauge. However, that sensor is in the cooling system near the thermostat. It is not in the carb. We need pix and you can use the insert image button on quick reply (thanks Jack) and browse to your computer.
