Post by nitroscoot on Feb 27, 2015 22:42:28 GMT -6
Ok - just bought a brand new taotao 150cc and having a minor problem. It starts fine but will not shut off. Here's what I have done and what I know right now. I have replaced the starter relay, the ignition switch, the CDI and coil and the the inline fuse between the battery and the starter relay. It keeps on running when trying to use the kill switch to shut it off, but, the bike will not start if the kill switch is not in the ON position, telling me the kill switch is ok. The bike is brand new and never been ridden on the street. Another thing I have discovered is that the bike will still run when completely disconnecting the ignition switch at the white plastic terminal that connects the wires that go back towards the engine. I have also discovered that there are two wires that that come out of the bundled wires in the back that go into the stator and that by discconecting either one, it kills the engine. One wire that does this is green/blue stripped and the other is red. Disconnect either one and the motor shuts off. Anybody have any clues about what to check next ? Thanks.
Post by Bashan on Feb 28, 2015 18:51:37 GMT -6
Your two wires from the stator that kill the engine are the CDI AC power and the trigger coil. The engine will not run without these wires. An AC GY6 creates spark right from the CDI, the spark does not run through the key. Once the bike is started you can unhook the key, and the battery, and it will continue to run. You must kill the engine with the killwire which is the black/white wire coming out of the two port on the CDI. Your bike is not shutting off because the killwire is not grounding out when the key is turned off. Check your connections from the killwire to key switch to ground wire. Something is not making contact. There's a tutorial on the GY6 ignition switch under electrical in the Library.
Post by nitroscoot on Mar 1, 2015 14:01:52 GMT -6
Thank you. i think I found the problem. I identified my system as AC and it looks like I am missing one wire from the small connector of the CDI. I should have two and there is only one. There should be another wire and I do not have a black/white wire plugged into the CDI.
Post by Bashan on Mar 1, 2015 16:33:29 GMT -6
That would be the killwire. You can hook it up to a switch that runs to a ground and it will do the same as grounding through the switch:
That is all the key does, it connects the kill to ground when you turn the bike off.
Post by nitroscoot on Mar 2, 2015 15:17:45 GMT -6
Hey man thanks for taking the time to point all that out. That was awesome. I actaully found the black.white wire plugged into one of the 4 plug holes. I unplugged it, put into the correct hole on the two port plug and bingo, all is good. Thanks again for your help.
Post by cyborg on Mar 3, 2015 8:37:27 GMT -6
I love it when a plan comes together
Post by Alleyoop on Mar 3, 2015 8:58:51 GMT -6
Thank you. i think I found the problem. I identified my system as AC and it looks like I am missing one wire from the small connector of the CDI. I should have two and there is only one. There should be another wire and I do not have a black/white wire plugged into the CDI. Yep that is what finally solved the problem the killwire coming from the KIllSWITCH and KEY was not plugged into The Top slot on the two plug of the CDI.
Post by jct842 on Mar 3, 2015 15:19:12 GMT -6
First one guys motor won't start and the second guys motor won't stop!
