Post by fisherman on Apr 10, 2015 7:51:11 GMT -6
I just got a Q6 full size ice bear 50cc trike and it wobbles when I turn corners,and is basically the roughest ride I ever had.shakes,and bumps,and I can feel every pebble on the road.Do all small trikes ride like this?
Post by cyborg on Apr 10, 2015 9:29:30 GMT -6
Smaller diameter tires do add a little "excitement " to the ride but nothing crazy,,,,, I would get the front end in the air and check the steering stem and all axel tightness to make sure you have everything snugged down to spec ,, and also the outside chance the rear wheels may be out of alignment with the frame,,, my money is on a loose steering stem / Axels and tire pressure
Post by Alleyoop on Apr 10, 2015 10:43:17 GMT -6
Check all the wheels for loose axle nuts.
