Post by twodogsnme on May 28, 2015 1:29:32 GMT -6
Ok scooterppl..I just put in a 26mm carb n a stainless cold air intake/air filter..turned air fuel screw 2 1/2 turns..adjusted to set idle..now I have good mid n high acceleration.. But it bogs n recovers after its warmed up..only happens from slow down/stop..when I give it a lil throttle it bogs fer a sec or two then picks up..more throttle better performance.. Any thoughts on this? PS installed new plug n ran fer a few (20 mins)..pulled plug..some soot..suspect a lil rich but understand this is better than lean..mayb adjust carb needle? All replys will b appreciated.. Keep the rubber down
Post by cyborg on May 28, 2015 10:42:38 GMT -6
I there is more than one clip groove go up one
Post by Alleyoop on May 28, 2015 11:45:57 GMT -6
If the plug is SOOTY it is to rich, since you slapped in a bigger carb(more fuel is being fed) try turning the Mixture screw clockwise 1/2 turn so it is 2 turns out and see if that helps it.
