Post by Alleyoop on Sept 9, 2015 15:43:00 GMT -6
What color are the wires on the plug that may help identify them. You will know if everything works then it is just a spare plug for some other option. Alleyoop
learning all I can.
Post by fox83 on Sept 9, 2015 22:53:28 GMT -6
Ok this is odd the wires are green and black/white. Which isnt that normally the kill switch wire....I went up and checked my ignition wires and there's a black and blue instead of black n white.. oh and the mystery plug is a two pin female plug.
learning all I can.
Post by fox83 on Sept 10, 2015 20:00:53 GMT -6
Is there anything else you can plug up that would run off the black/white wire...other than the kill switch?
learning all I can.
Post by fox83 on Sept 10, 2015 22:15:58 GMT -6
Post by Alleyoop on Sept 11, 2015 11:44:16 GMT -6
I can't think of anything but the Killswitch using the Black/White wire and the green right next to it to ground it out.
learning all I can.
Post by fox83 on Sept 13, 2015 10:38:11 GMT -6
Ok harness is on. Batt. is charging. Stator wires arent heating up so thats good..hopefully ill get good spark and get some kinda boom or pop or anything when I try to turn it over.
Post by Alleyoop on Sept 13, 2015 11:23:50 GMT -6
Great!! Give it a shot and Good luck.
learning all I can.
Post by fox83 on Sept 20, 2015 9:06:04 GMT -6
Ok so update put new harness on and stator but im getting no spark
Post by Alleyoop on Sept 20, 2015 10:10:25 GMT -6
Have you a ground wire from the motor to the frame? Check the killswitch, check the pickup coil for at least .25vac or little higher. Alleyoop
learning all I can.
Post by fox83 on Sept 20, 2015 11:31:33 GMT -6
Ok how do I check that
learning all I can.
Post by fox83 on Sept 20, 2015 11:33:28 GMT -6
Ok the scoots " turning over" but I got no spark I got my lights signals everything but stupid spark. Ive changed both the stator and magnito.
Post by Alleyoop on Sept 20, 2015 12:09:46 GMT -6
Here follow this Video testing for no spark: Alleyoop
learning all I can.
Post by fox83 on Sept 20, 2015 12:34:45 GMT -6
Ok funny story I had the wires messed up and had the two stators connected lmao. Now its fixed and bokes trying to start. It like get to that peak but wont fully turn over and start.but to check valves
learning all I can.
Post by fox83 on Sept 20, 2015 13:03:54 GMT -6
Great video bro. Im back to timing and valves. Guess they havegot out of time when I changed them.. hopefully I get it back I miss riding so much
Post by Alleyoop on Sept 20, 2015 13:18:27 GMT -6
How did it get out of time? I keep telling you guys BEFORE you go and take the head off, chain and cam. You need to bring it up to TDC align the CAM SPROCKET mark the chain and tooth on the cam and mark where the timing mark is pointing on the FLYWHEEL.
You can then take the whole motor apart but putting it back together all you do is line up the marks you made and it will be right on with the timing.
