Post by wanderingbiker on Oct 13, 2015 6:18:25 GMT -6
Im starting to seriously wonder why on earth i bought a Chinese engine now. Serious lack of customer support from the supplier and 0 response from the manufacturer.
I posted on here a while back about not being able to fix my electrics well after a few months and a lot of help from people here i finally got them to work. The only downside now, when i kick she doesn't start. every now and then she will fire but die and when she fires smoke comes out of the carb (defo smoke you can smell it too).
I know i have to sort the timing out, but all the manuals i find are for cam chain, but this engine is a push rod. Does any guru here know what feeler gauge to use to set the valves. what mm etc for both intake and exhaust.
I just bought the engine not a bike and I can't find another bike with this engine inside.
ENGINE:
170FMN yinxiang 300cc same as NT250 Push rod timing no chain
Thanks for any help its greatly appriciated.
Post by wanderingbiker on Oct 13, 2015 6:26:26 GMT -6
Sorry for got to mention that the engine is a copy from the Air Cooled Honda CG125 Engines spanning 1976-1991. This is the push rod engine that was used when creating the Chinese CG-200 and CG-250. Could i just grab the manual from carlsalter anduse the specs there
Post by cyborg on Oct 13, 2015 7:42:45 GMT -6
i'd use the honda manual for the motor this one is cloned after,,,i would think .004 for intake ,,, .005 for exhaust would do it but reference the honda manual
Post by wanderingbiker on Oct 13, 2015 9:18:09 GMT -6
The manual says both intake and exhaust 0.08. although the original is a 125 whereas this is a 300 so i would imagine its different ill try yours and try the manual. Would be so much easier if they just answered your questions when you email. hhhhmmm my gf is chinese malaysian so if neither of those work im goingto get her to call direct hahaha
Post by jct842 on Oct 13, 2015 14:55:10 GMT -6
Check on a chinese motorcycle forum, they will be more in tuned to what you have and will have links for manuals. With the exception to the latest engines they are using the push rod engines.
