Post by newscoot2 on Jan 28, 2016 17:45:32 GMT -6
Can anyone tell me why the fuel over flow is dumping the fuel during cranking. Happens when used electric start or kick start. Also it's not turning over and I just got this so I have no idea year or model. It has power just won't turn over and I put a new spark plug in.
Post by Alleyoop on Jan 28, 2016 18:49:11 GMT -6
Are you talking about the Fuel Overflow near the TOP OF THE CARB?
As for SPARK have you tested to see if the plug is firing? Take the BOOT CAP off the one on the motor and stick the old plug you took out in the boot and tyhen hold it against the valve cover and crank it and see if the plug is firing. Alleyoop
Post by newscoot2 on Jan 28, 2016 18:51:36 GMT -6
The hose that goes Down near the kick stand. And I'll try that to see if the plug is firing
Post by Alleyoop on Jan 28, 2016 19:17:24 GMT -6
The hose that goes Down near the kick stand. And I'll try that to see if the plug is firing That hose is your CARB BOWL DRAIN hose. It should have a screw on the end of the metal piece if so tighten it up. If no screw then you lost the shut off screw so you need to BEND the hose and zip tie nice and tight so it does not pour out the fuel. Alleyoop
Post by newscoot2 on Jan 28, 2016 20:23:52 GMT -6
That's it will do thank you
Post by dyoung1167 on Feb 7, 2016 11:47:03 GMT -6
the older carbs had the bowl drain screw on the bottom the the bowl instead of on the end of the tube that seems common now, so for giggles check if you have one that may just need tightening. crimping the tube will of course still work fine but it's worth checking.
