Post by mike932 on Apr 27, 2016 15:02:17 GMT -6
My Buddy 170i right mirror vibrates a lot when idling which makes it hard to see cars approaching behind me. How can I reduce the vibration?
Post by Alleyoop on Apr 27, 2016 15:26:05 GMT -6
That is a sign the carb needs a little tweak and you need to find where it idles the smoothest. So you may need to up or lower the idle to find where it idles the smoothest. But usually you need to adjust the carbs fuel ratio mixture it is a little off and not running the best.
Post by mike932 on Apr 27, 2016 16:31:25 GMT -6
It is fuel injected. Do I need to adjust valves?
Post by Alleyoop on Apr 28, 2016 18:19:39 GMT -6
If it is hard to start then I would adjust the valves, try adjusting the idle AFTER it warms up.
Post by mike932 on Apr 28, 2016 20:17:47 GMT -6
It is not hard to start at all.
Post by Alleyoop on Apr 28, 2016 20:46:24 GMT -6
Good then valves do not need to be adjusted. So adjust the idle is your only hope
Post by jct842 on Apr 28, 2016 21:02:17 GMT -6
Sometimes bar end weights make a big difference in vibrations on the handlebars.
