Post by deak on Apr 8, 2019 11:23:40 GMT -6
Hi! I am having trouble getting my scooter started. It fired up, and I went to the gas station. After filling, it wouldn't start, but would almost fire. I got it home, checked the timing, and air filter, and it still won't run, but almost does. Any help?
Post by deak on Apr 8, 2019 11:24:49 GMT -6
It's an icebear 49cc, and only 1400 miles
Post by cyborg on Apr 9, 2019 6:55:47 GMT -6
If it's a 4 stroke you need to adjust the valves
Post by deak on Apr 9, 2019 11:04:14 GMT -6
Did it, the weird thing is, it was running and I went to the gas station. It just wouldn't start after that.
Post by cyborg on Apr 10, 2019 8:12:45 GMT -6
You sure you did them correctly? By the symptoms you describe it sounds like classic valves to tight and a valve is hanging open
Post by deak on Apr 10, 2019 11:52:02 GMT -6
Yes, I've been adjusting my valves, without any problem. Could it be fuel?
Post by kz1000st on Apr 10, 2019 16:22:33 GMT -6
Does it have a charcoal evaporate canister? If you overfilled the tank it screws up the tank venting. Try taking off the gas cap and see if that works.
Post by cyborg on Apr 11, 2019 7:04:06 GMT -6
HA!! Beat me to it,,,that was my next post
Post by deakypoo on Apr 17, 2019 11:43:53 GMT -6
Sorry, I've been busy with work, I've rechecked the valves, and in checking the fuel, I've pulled the fuel line from the fuel filter, should I have flow?
Post by kz1000st on Apr 18, 2019 9:41:31 GMT -6
There won't be any flow if the engine isn't running. The fuel valve is vacuum activated . If you suck on the vacuum line fuel should flow.
Post by cyborg on Apr 20, 2019 8:23:41 GMT -6
Could be a bad vacuum fuel valve or the vac line may have a small crack
Post by normy41 on Jun 4, 2019 12:43:48 GMT -6
Hey I have a brand new Bintelli 50cc IceBear that I just bought and am having electrical issues. I have 12 volts of power going to the horn and turn signals but nothing at the start or kill switch? I also do not have any power going to my head light. tail light and no brake indicators. I can't take it back to the dealer because I am some 1800 miles away from where I bought it on vacation? Can anyone help out? Thank you!
Post by cyborg on Jun 5, 2019 6:35:18 GMT -6
Sounds like you popped the main fuse
Post by unmechanical on Jun 24, 2019 20:24:42 GMT -6
Before my ice bear scooter "Ruckus Clone", stopped running and fuel was leaking out of the exhaust every time i turn over the starter. I replaced the battery and i want to replace the spark plug but cant find that? what else do you think can be the problem?
Post by cyborg on Jun 26, 2019 9:03:01 GMT -6
Plug is in the head of the engine,,it sounds like it's flooding,,,carb float needle valve is stuck open
