Post by cyborg on Jul 12, 2019 8:10:19 GMT -6
You need to find the spec on those sensors,,,then check your resistance against the spec
Post by jmicester on Jul 12, 2019 15:07:45 GMT -6
You need to find the spec on those sensors,,,then check your resistance against the spec What is spec?? And how do I go upon testing the resistance? I grounded the wire that goes on the cylinder thermostat sensor and my gauge went all the way up to the H. Does that mean that the cylinder temp sensor is bad??
Post by cyborg on Jul 15, 2019 7:08:18 GMT -6
Yes that's a good assumption ,,this is how these sensors work,,,it's a variable ground
Post by jmicester on Jul 19, 2019 3:39:43 GMT -6
Looks like the new sensor worked! Thanks
Post by cyborg on Jul 22, 2019 7:28:21 GMT -6
YEA BABY!!!! Good diagnosis,,solid repair!! There's a piston right there
