Post by sirus187mdk on Nov 25, 2019 12:07:52 GMT -6
I'm currently trying to undo the bodge up wiring that has been done to this bike. I only brought the bike the other day as a cheap runner for work and it got me through one shift and then herd a like a high scream and then bogged and died. I changed piston ect as was broken and I still can't get her to turn over. any help getting her running again would be a god send. For some reason I now have no spark at all. All electronics work fine except no spark. I was at one point getting spark but it was very dull and very intermittent now I have none. Could anyone suggest the most likely thing for it to be and is there any wiring diagram floating around for this model? I only brought the bike the other day as a cheap runner for work and it got me through one shift any help getting her running again would be a god send.
Post by cyborg on Dec 4, 2019 8:33:14 GMT -6
Most likely the pickup sensor not sending a signal to the cdi,,,but first check all the grounds from the battery to the frame and make sure all the battery terminals are clean and tight
