Post by Alleyoop on Jan 4, 2012 21:47:32 GMT -6
TDC=TOP DEAD CENTER, When the Cam Sprocket holes are aligned like you have them you should be able to wiggle the ROCKERS with your fingers. They should be CLOSED and off the HIGH LOBES on the cam. Alleyoop Before you take the chain and cam off ALWAYS Mark the chain and a tooth on the cam. This way if you do not take the chain off the Sprocket on the Crank you will always get the chain and cam on the right and not OFF 1 tooth. Alleyoop Mark it like this SEE THE WHITE MARK, marks the chain and tooth.
Post by seanstr on Jan 5, 2012 20:18:26 GMT -6
TDC is what
Post by jct842 on Jan 5, 2012 20:19:13 GMT -6
top dead center referring to the piston at the very highest point
Post by seanstr on Jan 5, 2012 20:19:38 GMT -6
Ok, , closed & off?
Post by seanstr on Jan 10, 2012 7:17:21 GMT -6
Ok, someone had idea to take out spark plug, put a straw in it, this will tell me the tdc & then match tdc on camshaft. Good idea?
Vespa Specialist
Post by Kaveman on Jan 10, 2012 11:45:58 GMT -6
Top Dead Center .
Post by Alleyoop on Jan 10, 2012 12:18:35 GMT -6
Ok, someone had idea to take out spark plug, put a straw in it, this will tell me the tdc & then match tdc on camshaft. Good idea? Yes that will help when it is at TDC you SHOULD be able to wiggle BOTH ROCKERS they will be OFF the HIGH LOBE of the CAM IN THE CLOSED POSITION. Alleyoop
Post by seanstr on Jan 12, 2012 5:18:10 GMT -6
Ok, I strongly believe the timing is right, but I had battery turned on it's side, & the juice required to start is not enough, now what
Ok, it behaved differently a appeared to be attempting to start, until juice ran out quickly. Is battery repairable? Check fluids etc.
Post by sprocket on Jan 12, 2012 14:46:57 GMT -6
Most of these batteries are sealed...have it load tested at an automotive place...
They are not repairable...
Post by jct842 on Jan 12, 2012 18:33:03 GMT -6
charge the battery! if you have been trying to start all this time with out a charge on the battery it is just needing a charge.
Post by seanstr on Jan 12, 2012 21:15:06 GMT -6
I totally turned it sideways. Some fluids came out., water. Anyway, I opened it, put some water in, closed it back up, re-glued it, it's on charger. See if that helps. I doubt it. I want to just replace it. How do I tell type I need?
Post by Alleyoop on Jan 12, 2012 22:26:40 GMT -6
The important thing is measure the length, width and height of the battery. They are all 12 volt batteries but you can get them in different OUTPUT AMPS. Your battery should say how many amps it is on the side of it probably a 7amp battery. The size is important because your battery compartment on the scoot may not be able to take a LARGER SIZE battery. You can get batteries for them in a lot of places some are cheap batteries some are really good batteries with warranties. It depends how much you want to spend anywhere from say around $40.00 on up. If yours is a 7Amp battery if you can find a 9amp battery the same size that would be better it will have more CRANKING POWER. Just google for motorcycle batteries and find one the same size as what will fit in the battery compartment. Alleyoop www.batterystuff.com/batteries/motorcycle/sYTX7A-BS.html
Post by dryshave on Jan 14, 2012 12:37:21 GMT -6
Alleyoop - bringing our conversation forward into this thread as I'm not double checking my TDC alignment. I've visually checked my TDC through the spark plug hole and can see that it comes to TDC I've matched to the T mark as well as the small circle on the cam. My cam has only one small stamped circle on it unlike the one you've illustrated. I'm almost 100% sure I'm at TDC, but am pulling the valve cover over the weekend to be absolutely sure that I am correct. I don't think that I am an entire tooth out, but as I'm pulling the carb again!!!!... I might as well satisfy my doubts.
