Vespa Specialist
Post by Kaveman on Jul 28, 2012 20:06:37 GMT -6
Vespa Specialist
Post by Kaveman on Jul 28, 2012 20:21:53 GMT -6
One more quick note : the 2 cycle Vespa's and Stella 2T's (made by LML in India) don't have a twist and go transmission like the Chinese scooters have . The original Vespa scooters in the late 50's initially had a 3 speed manual transmission. Piaggio later went to a 4 speed manual transmission that was carried into the PX and later on the LML made Stella 2t's.There are no belts or weights in the transmssion like the chinese scoots have . Everything is gear ratios . It took me close to 2 months just to get used to the shifting patern that my Stella 2T has . What was my rear brake lever on my old Roketa is now the clutch and the shifting is done with the left wrist. The rear brake is now on the right floorboard. One last note : (My opinion )The Vespa and LML parts quality are far more superior than what the chinese scoots have. They last much longer !! will c.
Post by jct842 on Jul 28, 2012 23:21:58 GMT -6
The rear brake has been on the floor boards with most scooters for a long long time. Even the twist a go scooters. It was just the last few years that they went to a left hand brake lever. I think right up the the last honda helix they had the floor brake. I am thinking the feds may have had some thing to do with the hand brake lever over the floor brake. I think the hand brake might just be a tad quicker to apply is the reasoning. I had a wards branded mitsubishi silver pigeon in 1958, twist and go and a foot brake. It takes some thinking when I ride my riva after a majesty or my 150 chinese as it is foot brake.
There are some who have grafted a vespa straight into a stella with no problems at all so you are on the right track possibly swapping internals.
john
Post by Bashan on Jul 29, 2012 7:33:47 GMT -6
Wow, very nice and informative thread already Will, thanks for taking the time to put that together. I look forward to future additions on your project. We finally got somebody around here that knows what the hell their talking about with two strokes. Rich
Vespa Specialist
Post by Kaveman on Jul 29, 2012 11:08:27 GMT -6
Here is one more picture that shows the difference of cylinder bolts holes on the Vespa P200 crankcase when compared to a Vespa VLB1M ( Sprint 150)crankcase . The bolt holes are digonal instead of horizontal like on the VLB1M crankcase (left picture) .
Vespa Specialist
Post by Kaveman on May 6, 2021 12:27:06 GMT -6
This is my first posting here in a very long time. So here is an update on my project. The engine has been running relatively well since being built. The cylinder head had to be replaced 2 seasons ago. Last spring I decided to try a Cosa type clutch. This type of clutch was an upgrade from the standard clutch basket and has 8 smaller springs but uses similar cork clutch plates. Using the stock clutch was getting to be a bit of a pain when riding about Boise. Having had 2 standard type clutches in row come apart inside the clutch area, I decided after digging on the issue online that I needed something that would be a bit more rigid and durable. The outer edges on the standard clutch baskets I was using that held the retaining circlip were opening out,causing the clutch to come apart. This was most likely due to the high centrifugal forces during high speed operation @ 50+mph. The cosa type clutches are built a bit differently but interchangeable with the large frame clutch's I had previously been using. After getting it installed I noticed a huge difference concerning the clutch. The clutch is actually a bit easier to activate and less tiring to use compared to the stock 7 spring clutch I previously used. Also I don't have to use the old castle type nut that bolts the clutch to the crankshaft. The cosa clutch uses a flange type nut instead that uses a standard metric socket instead of a special tool to tighten or remove the castle nut commonly used on the older vespa scooters. One less special tool to pack around in my scooters glove box. The scooters frame now has 11,000 + miles on the odometer . Not a pretty as she was when I got her but still putting along with maintenance when needed. What I am hoping with the cosa clutch I am now using is that I won't have to replace the clutch cable as much like I used to with the older style clutch I was using.They were snapping every so often due to the high tension on them. There is less tension on the cable now with the cosa installed. More as thing scoot along. willc. One other note : The cats still run the house!
Post by geh3333 on May 8, 2021 18:52:39 GMT -6
I just bought a couple new scoots 5he "spark 150's" and I'm really impressed with these scoots compared to the one I had back in 2014. It has the 14 inch wheels and even has Bluetooth with a charging port , sd port and controls for volume ,track change and a small speaker which I can surprisingly hear, lol. I bought a few cvt and engine upgrades .
Post by geh3333 on May 8, 2021 18:56:48 GMT -6
