Post by hiram357 on Apr 3, 2013 17:33:40 GMT -6
Greetings!
Alright, so around the new year I got a new scooter. A 150CC Kinroad for 850$ with only 4 miles on it. When I went to the guys house to pick it up, he turned it on and showed me everything.
This scooter has emergency blinkers on it, and I noticed, after I took it home that only 3 out of 4 blinkers were working. That is no biggie to me. So one night I go to ride my scooter to the store and notice my dash and headlights were not coming on, but ALL my blinkers were on?
I'm not too mechanically inclined, so I am not too sure what to do. Try to find the cord to disconnect the emergency blinkers or what?
Post by hiram357 on Apr 3, 2013 20:32:07 GMT -6
Post by Alleyoop on Apr 3, 2013 20:35:08 GMT -6
There is a button or switch to turn them on and off. Alleyoop
Post by hiram357 on Apr 3, 2013 20:48:09 GMT -6
If you're talking about the blinkers, it doesn't matter if they are on or off my headlights still won't come on.
Post by Alleyoop on Apr 3, 2013 20:51:04 GMT -6
Some have a headlight switch to turn them on or off on the right side handlebar. Or does yours come on automatically once the key is turned on? Alleyoop
Post by hiram357 on Apr 3, 2013 20:53:18 GMT -6
Ahh. I have one of those, too. But usually my headlights come on once I start it up, and I can use the switch to turn it from high to low or low to high.
Post by Alleyoop on Apr 3, 2013 21:02:56 GMT -6
Well give the switch a try and see if they come on low and or high. If in the middle they are probably completely off. Alleyoop
Post by hiram357 on Apr 3, 2013 21:15:37 GMT -6
That's what I've been doing and they haven't been coming on at all. It's been this way for a few weeks.
Post by Alleyoop on Apr 3, 2013 21:23:47 GMT -6
Well you are going to have to check the wires going to the switch and follow down and see if maybe they got unplugged. Many times the wires are around the fork and when you turn it pulls on the wires and unplugs them. Alleyoop
Post by hiram357 on Apr 3, 2013 21:28:40 GMT -6
Thanks. Would Ii have to take something off for this?
Post by Alleyoop on Apr 3, 2013 21:52:35 GMT -6
Yep, the front cowl that goes around your headlights to get at the wiring behind it. Alleyoop
Post by hiram357 on Apr 3, 2013 21:57:17 GMT -6
Thanks pal, I'll try and do it in the AM. Appreciate the advice.
Post by Alleyoop on Apr 3, 2013 22:23:56 GMT -6
Your welcome, if they were working before it has to be something got unplugged by accident. Alleyoop
Post by hiram357 on Apr 4, 2013 5:03:55 GMT -6
Took off the front, everything seemed to be hooked up,
Post by Alleyoop on Apr 4, 2013 10:07:45 GMT -6
Find your Regulator/Rectifier and check that everything is plugged in good, also check the wires coming out of the STATOR, here is a picture of how yours may be wired. Notice the wire for the headlights. Alleyoop
