Post by sabotendar on Mar 26, 2014 12:01:58 GMT -6
Hi guys, I´m loking for squematics or pinouts from this CDI he is not working anymore and i like to replace with another one is possible to place anoter compatible whit this CDI?
Post by Alleyoop on Mar 26, 2014 12:50:12 GMT -6
Post by Deleted on Mar 26, 2014 13:15:30 GMT -6
yeah id contact them. went to the site and that is not shown there but its possible they may have some left if the scooter isn't too old. sites kinda outdated looking and hard to use.
Post by sabotendar on Mar 26, 2014 13:58:14 GMT -6
I contact them but, on 2 months later, but no one make contact with me...(sorry for my poor english).
Post by Alleyoop on Mar 26, 2014 14:07:19 GMT -6
What is the name and model and year of your scooter? That may help in finding that specific CDI. But what I would do is follow the wires you labeled and find out where they go and come from. It may be that a regular CDI may work and all you would have to do is change the PLUG on the wires on the other end. So if you can do that and tell us where EACH of those wires go and come from we can tell you if a REGULAR CDI will work. Because it is very similar to a regular CDI just a couple of the colors on the wires don't match BUT if they come and go to the same place as a regular CDI does you may be able to switch over to a common CDI. Alleyoop Here is a common CDI that just about all scoots have:
Post by sabotendar on Mar 26, 2014 14:20:47 GMT -6
Post by Deleted on Mar 26, 2014 14:26:52 GMT -6
ok is this a 4 stroke GY6 engine or is it a 2 stroke 1e40QMB or something like that? I looked it up and got nothing about engine type. airbox makes me think 4 stroke.
Post by sabotendar on Mar 26, 2014 14:37:49 GMT -6
He use 2T oil on the gasoline mix so i think is a 2T engine (1e40QMB) the carburator and the automatic choke is broken too and i will replace with a new one with no automatic choke. But i dont have any clue on how to replace the damm CDI since i cannot find the original in my country (Brazil).
Post by Alleyoop on Mar 26, 2014 14:43:57 GMT -6
Look at my reply and FOLLOW THE WIRES on your OLD CDI and tell us where EACH WIRE GOES TO.
Alleyoop
Post by sabotendar on Mar 26, 2014 14:52:49 GMT -6
Ok im very grateful for your help and i back here here soon i can see where each wire is going...
Thanks.
Post by Alleyoop on Mar 26, 2014 15:04:18 GMT -6
Great!! Maybe another CDI will work. Alleyoop
Post by sabotendar on Mar 27, 2014 7:02:24 GMT -6
Hi, Here the schematics of the CDI on my scooter, he is a DC-CDI?
Post by Alleyoop on Mar 27, 2014 12:48:54 GMT -6
One of the ELECTRICAL gurus I am sure will chime in and be able to verify whether a common 6 pin CDI will work and you would need to get the plugs and rewire them in the right positions to be plug and play with common 2 and 4 CDIs. Alleyoop
Post by tvnacman on Mar 27, 2014 14:29:41 GMT -6
Hi, Here the schematics of the CDI on my scooter, he is a DC-CDI? I need some info here : the BL from the ignition switch what is it doing in the on and off position . Then the y/w off the stator to the rectifier then turns BL/W what is the voltage while cranking and is it AC or DC voltage ? Please add the info to the diagram . John
Post by Alleyoop on Mar 27, 2014 14:40:17 GMT -6
If it is a DC CDI then when the KEY IS ON it should send 12v to the CDI. Do you have a battery in the scoot and is it good? If so check at the IGNITION and see if the wire from the battery is getting 12v at the IGNITION SWITCH. There should also be a FUSE on that wire if no juice at the Ignition switch it maybe a bad fuse. Alleyoop
