Post by tank2014 on Apr 10, 2014 16:26:25 GMT -6
Hello,
I recently picked up an 08 slight basket case tank 150cc for 200bucks. After fixing a bunch of stuff on it including replacing a lower steering bearing that the PO had misplaced, it is now solid with the exception a draining battery. Battery is a new Yuasa and will discharge while hooked up in about two days.
Scooter will keep running just fine with the battery disconnected. I took out the alarm due to hearing that that is a possible problem with battery drains. I just noticed that the scooter starts without the key in and also with the plug for the ignition key completely unplugged. Do the alarms need to be plugged in for the key switch to actually function? Any ideas on where to start looking for the battery drain problem.
Thanks in advance, I enjoy reading what you all have to say.
Post by Bashan on Apr 10, 2014 20:02:38 GMT -6
Put a multimeter on the battery while it's running and see what the voltage is. That is normal for them to run without the battery. The spark is generated by the stator/CDI and the battery has nothing to do with that on an AC system.
Post by Alleyoop on Apr 10, 2014 20:22:56 GMT -6
How to disconnect alarm/remote: Alleyoop
Find the alarm/remote start module and find the white plug for it. Unplug it from the wiring harness then check the wire colors if you have a brown/white and a black/white OR 2 black/white wires in the harness plug join them together with another wire. Or it may have grey and pinkish color wire connect those. If the alarms have a fuse just remove the fuse and leave it plugged in.
Post by Bashan on Apr 10, 2014 21:48:15 GMT -6
I did not know that...,.thanks Alley. Don't hurt me.
Post by tank2014 on Apr 15, 2014 14:40:38 GMT -6
Thanks Alleyoop and Bashan,
Im getting weird readings with two different multimeters when checking battery, lots of fluctuations and can not get a solid number, could be cheap multimeters.
What I did was unhook the battery and checked for continuity. Circuit was closed when checking this way so there was definitely a draw on the battery. I started to unplug connectors and circuit finally was open when I unplugged the alarm, so in my case the culprit was a short in the alarm. Using your advice Alleyoop, I bypassed the alarm. With the Tank's wiring harness, there are two black with white striped wires and these were the ones that need to be jumped.
Everything seems to be working with exception of the head light being off until you turn it on. Prior to this it was always running.
Post by Alleyoop on Apr 15, 2014 14:57:30 GMT -6
Thank you Tank, I added the 2 black and white wires to my alarm/remote disconnect how-to. Alleyoop
