Post by mtj on Apr 19, 2014 12:54:40 GMT -6
2012 motobravo hornet swing arm cracked n need a replacement I can't find a scooter shop that carries this part n I tried looking online at motobravo parts n can't seem to find it...any help will be greatly appreciated. This bike is my commuter to work.
Post by Bashan on Apr 20, 2014 0:07:55 GMT -6
You need to post a pic of it so there is no confusion on a part as critical as that.
Post by Alleyoop on Apr 20, 2014 0:26:52 GMT -6
Or you can take it to a Welder and have it U.S.A welded Alleyoop
Post by mtj on Apr 20, 2014 13:16:14 GMT -6
I will post pics asap I ended up using quick steal paste to temporarily hold the swing arm together but I'm almost sure the arm is made of Casteel n km not sure if you can weld . I would prefer a replacement.
Post by Deleted on Apr 20, 2014 13:21:38 GMT -6
no no no! dont ride it like that! it could crack the rest of the way and fall apart! you might not be around to ride it again if it came apart at speed!
Post by Alleyoop on Apr 20, 2014 13:49:08 GMT -6
Yes, it is not save to ride it with a cracked swingarm, if it brakes off you can kill yourself. That paste or whatever you used is not strong enough. Alleyoop
Post by tvnacman on Apr 20, 2014 14:13:28 GMT -6
What size wheels 50 or 150cc ?
Post by mtj on Apr 20, 2014 18:14:51 GMT -6
the corner of the swing arm by the bolt is where it cracked i did my best to seal it with quick steal and bolt it back in place, reassembled everything back. Part didn't have an item # so im back at 0 again so im looking for a welder in my area but if anyone point in the right direction it would be greatly appericated.
Post by mtj on Apr 20, 2014 18:15:42 GMT -6
its a 150 cc
