Post by chuck01 on Apr 22, 2014 10:40:42 GMT -6
I found the problem with my not idling, replaced the carb.. Now this unit runs fine except when you let off the throttle, then unit stalls out. I've been reading about adjusting the fuel mix on my 50cc 4t, but there's no adjustment screw!! WHAT??
Post by Alleyoop on Apr 22, 2014 11:19:16 GMT -6
You bought a carb with the Fuel Ratio Screw PLUGGED!! Got's to always check out the carb before buying that is the first time I heard of an AFTERMARKET carb with a plugged mixture screw. Well you have 2 options drill out the plug to get at the screw or buy one without the plug. It may be that the idle is set to low try raising the idle using the IDLE SPEED screw and see if it will not die. But eventually you will have to get at the Fuel Ratio Screw for Temp changes they set those suckers really lean then plugg them up. Alleyoop
Post by Bashan on Apr 22, 2014 19:39:22 GMT -6
Post by chuck01 on Apr 23, 2014 8:42:11 GMT -6
Thank you! This will help greatly.
