Post by watson492 on Mar 26, 2015 8:26:08 GMT -6
hey.... well all sorted .. dug a little deeper and turns out was clutch. decided to try the 1 from engine i replaced. stripped clutch from bike and found that there were no return springs (none out of the 3) swapped clutches over started bike and wahoooo works a treat . and would just like to say thanx for ya help dude mucho appreciated
Post by watson492 on Feb 28, 2015 10:16:33 GMT -6
well just had good going over airbox no leaks on that, and the carb seems to be working fine also.injector looks ok with no drips when engine off. might have to be a shop visit(or closest lake lol) watson
Post by watson492 on Feb 27, 2015 14:50:34 GMT -6
cheers will look into it in morn...also its fuel injection and the carb(carbish lol) is butterfly and not slide version, and seems to be working fine ive even tried mine of my engine, so hopefully its the airbox.... cheers again m8y... watson
Post by watson492 on Feb 27, 2015 4:30:29 GMT -6
hi all .. iam new to the forum, so hi from n.e. uk .. am looking for help with ma max, i have just sorced a replacement engine , ive got it swapped over everything is running BUT ! when its meant to be ticking over its running with a load on! can disconnect throttle cable and even take idle screw out but still same... any help mucho app .... watson
