Post by grrbrts on Dec 1, 2023 19:47:06 GMT -6
If yours has a flame-out switch, check that it works by switching it on and off. If not working, replace that switch. Check to start button as well. Make sure both are getting fire, so to speak.
GY6 180cc
by: grrbrts - Jun 3, 2023 5:07:51 GMT -6
Post by grrbrts on Jun 3, 2023 5:07:51 GMT -6
Did you upgrade the flywheel?
GY6 180cc
by: grrbrts - Jun 1, 2023 19:32:31 GMT -6
Post by grrbrts on Jun 1, 2023 19:32:31 GMT -6
How do you know if it is getting good spark, if it won't turn over?
Post by grrbrts on May 31, 2023 10:48:47 GMT -6
Hey, that is fast!
Post by grrbrts on May 31, 2023 10:47:57 GMT -6
My speedometer gauge is off by 10 miles less than what is shown.
Post by grrbrts on May 30, 2023 7:34:21 GMT -6
I took the plastic piece off. I think the kickstart shaft is stopping it. I am thinking about cutting the foot peg off, then the cover will be in position to just pull straight out/off. I can always get it welded back. I just need a hacksaw now. It is easier to that than to remove the engine mount bolt and shock. If you, are anyone else finds out another way, please reply. Thanks in return. I love your modification! I am afraid to install that alternative, in that someone could gain access to the belt and cut it, or too much exposed to the weather (rain). What is the weight/sliders are the rollers you are using, as well as the clutch springs? Also, what size belt are you using? I live in a hilly part of the county. I cruise at 45mph max, sometimes 50mph.
Post by grrbrts on May 29, 2023 11:06:19 GMT -6
I cannot get the cover off because the foot peg is in the way.
Post by grrbrts on May 28, 2023 19:35:20 GMT -6
How do you take the variator and clutch cover off? It was quite easy on my Roketa.
Post by grrbrts on May 11, 2023 7:47:37 GMT -6
Post by grrbrts on May 11, 2023 7:37:46 GMT -6
Hey, you are right! It is a long case, and it has 10 bolts. Thanks my friend.
Post by grrbrts on May 10, 2023 20:53:33 GMT -6
Thanks, I will post pictures tomorrow.
Post by grrbrts on May 10, 2023 8:50:20 GMT -6
I own a Vitacci Sparks 150 Scooter which has a short case with 14" rims. Is there a difference in the input and output shaft lengths, as well as the fitting of the gears, bearings, and seals?
Post by grrbrts on Dec 16, 2022 7:35:04 GMT -6
I have a 2020 Vitacci Sparks 150cc scooter. Normally, the headlights turn on once the key is turned on. I added a pair of rear-view mirrors, and now the headlights turn on once it is started. I noticed a device about the size of a dc-fired cdi. Could it be a ballast, or perhaps a resister of sorts? See images.
Post by grrbrts on Sept 26, 2022 8:26:59 GMT -6
Does anyone know what the number embossed on the carburetor where the automatic choke attaches to stand for?
Post by grrbrts on Jan 15, 2021 18:49:36 GMT -6
Anyone?
