Post by dyoung1167 on Jun 20, 2023 16:25:19 GMT -6
some times mine does that, a little jab at kickstarter gets it back into working order, almost like it's missing a tooth but i don't think so. probably just sticking as the spin should push it into place to engage
Post by dyoung1167 on Dec 3, 2022 17:01:00 GMT -6
so I'm under the impression a 150 typically uses 13-40/42 final gearing and curious if 15-37T is too long for normal driving. I seem to ba having difficulty in finding a set that is already pressed without the utter price gouging by some sites, such as 75 for the gear and 75 more to press it for ya. that said i have been able to find only one set that isn't normal factory gears and they are 15-37 for like 40 bucks. I'm looking a step up in top speed but not looking to completely kill takeoff. any thoughts?
Post by dyoung1167 on Oct 12, 2022 21:58:25 GMT -6
Ok, so several years ago i did an 11 pole 3 phase/fullwave up grade on an older scoot. it was a 5 wire set up. stator had five - 3 for r/r and 2 for cdi and triger. no probs. initial scoot needed wire for rear running light connected to dc as no more ac for it. no prob. worked pretty good. car pulled in front of me and totaled scoot. got another crapty arse franken scoot to swap motors and keep getting it. totally no thoughts about rear running light but it worked. I now have a new ice bear 150 hurican with new engine deciding to spew oil from air filter box as that's were the over pressure line from valve cover goes and decided to to replace with older engine with full wave 11 pole stator. in the process i decided to test the r/r and found it defective so i order another "5" wire full wave r/r as that is exactly what was paired with stator new (they were a set). rear running light is of course ac so i ran a new dc wire for it and of course changed over headlights to dc also. seemed to work, until the next day. now my headlights and blinkers take turns being on and my the blinkers are bleeding to other side, as in left blinker on is bright but right blinker is also on but dim. most r/r's i first saw were 6 wire but since original was5 thats what i eventually searched for and bought. what the hell is the 6th wire for if i bought one or is there one that would simply take over as yellow from the half wave original so i only need to to convert the headlights from ac
Post by dyoung1167 on Sept 22, 2022 13:34:06 GMT -6
Post by dyoung1167 on Sept 22, 2022 13:30:40 GMT -6
thinking it's the typical crap bulb that i cannot think to name but can be replaced with h4 as the base used in the crap bulbs also gets replaced, but probably need to buy the connector too as they do not match but easy and cheap. most direct bulb only leds are also junk
Post by dyoung1167 on Sept 22, 2022 13:24:31 GMT -6
can you post pics? close-ups all around fairing area including from the top of dash etc. this for us to see posible mounting points or maybe some type of rear access such as through glove box etc?
Post by dyoung1167 on Jul 3, 2022 17:25:09 GMT -6
to begin you can change how high the main needle in the carbe to ride higher making run a bit richer but probably not help with your prob as it is more likely the idle jet causing the lean after throttle drop. kits with numerous size of both low speed and high speed jets are fairly cheap and easy to mess with. there are probably threads on here to better explain and many ytube vids out there.
Post by dyoung1167 on Jun 29, 2022 19:41:49 GMT -6
do not waste your time here, it's dead as f%^k and completely worthless. If you should find one that works please give me a heads up at dyoung1167@hotmail.com
Post by dyoung1167 on Jun 29, 2022 13:16:50 GMT -6
i will say that it is a what ya call it ca head for emissions that has been properly blanked at the cylinder block and a non emissions head and valve cover. this was changed just a few weeks ago do to a broken exhaust manifold bolt. I have done this before on an older scoot without causing this. It seems to run fine with descent takeoff and power so i don't think i'm loosing any compression. could it be maybe a badly done valve adjustment? Maybe one tooth off in one direction or another with the timing chain? Like said, i've done this type of thing before without issue but want a more precise place to start before i start tearing crap apart. I don't remember trying so damn hard to get piston at true tdc and the valve sprocket exactly center the first time as i did with this one so is there maybe a slight offset i may have missed?
Post by dyoung1167 on Jun 29, 2022 12:59:11 GMT -6
found after scoot dying from somehow having water in gas, i pulled box from under seat to manually put suction on vac-petcock and oil seemed to be everywhere yet not from engine itself as plastic shroud would have kept it all within said plastic or i should say keep it from going over and beyond. I haven't yet opened air filter as i know breather tube from valve cover goes to it and should have the foam and cover over that little port but sure seems to be a good bit more than a little bubble of oil every once in a while and acting as its own catch can which is pretty much exactly its purpose
Post by dyoung1167 on Jun 29, 2022 12:48:43 GMT -6
has it ever ran? one thing i hate on new scoots is the damn need for kickstand to be up. very hard to get to switch itself but i was able to locate a connector for said switch and unplug it
Post by dyoung1167 on Jul 18, 2021 10:37:09 GMT -6
is your idle is too high forcing the clutch to engage slightly? Check all springs associated with the clutch
Post by dyoung1167 on Apr 4, 2021 14:30:59 GMT -6
yes but no, it cannot be both xenon and led. If it actually is led then no because most scoots are running the headlights with ac from the stator, so it needs rewired for dc
Post by dyoung1167 on Dec 7, 2019 18:39:35 GMT -6
let me know if you find any place for parts. I have one but I can't get a good book on it without paying $75, and i can't seem to find a real place with parts, lots of the yes we claim list parts for googles sake but none of them do.
Post by dyoung1167 on Jun 24, 2018 12:46:32 GMT -6
I had a scooter that went through belts way to often and finally bought another. by chance they were side by side with the belt covers off and out of the corner of my eye I saw that the belt issue scooter was not truly aligned from variator to rear pulley so that the belt was not straight and why I was building up so much more heat and shredding belts. I never really looked into the cause because someone bought it for parts but it's worth looking into. Maybe one of the two pulleys had an extra washer or the need of one to line them up properly. the new scoot (and the one that was bad were both unboxed new by me)never had that issue.
