Post by cyborg on Jun 8, 2020 7:31:48 GMT -6
Good repair
YJ50 bogging
by: cyborg - Jun 8, 2020 7:30:56 GMT -6
via mobile
Post by cyborg on Jun 8, 2020 7:30:56 GMT -6
Carbed main jet clogged or rip in diaphragm injected not enough fuel pressure fuel pump may be going away
YJ50 bogging
by: cyborg - Jun 8, 2020 7:29:29 GMT -6
via mobile
Post by cyborg on Jun 8, 2020 7:29:29 GMT -6
Injected or carbed?
Post by cyborg on Apr 30, 2020 6:52:11 GMT -6
Talk to Jim at rapid repair,,,he's the icebear guru,,he'll know what you need
Post by cyborg on Apr 30, 2020 6:47:22 GMT -6
Drop down to 120 main
Post by cyborg on Apr 30, 2020 6:44:58 GMT -6
4 thousandths on the valves,,,I'd think you'll need to test the auto choke and I'd go thru the carb to make sure it's clean
Post by cyborg on Apr 30, 2020 6:40:17 GMT -6
Emo,,yes the machine has an auto choke
Post by cyborg on Apr 27, 2020 20:58:34 GMT -6
Carb needs to be gone thru
None starter
by: cyborg - Apr 27, 2020 20:56:04 GMT -6
via mobile
Post by cyborg on Apr 27, 2020 20:56:04 GMT -6
That sounds about right
Post by cyborg on Apr 16, 2020 7:14:47 GMT -6
Pull the diaphragm cap,, check to see if the diaphragm has a crack in one of the pleats or a hole,,, also see if the slide works easily in its track,,,
Post by cyborg on Apr 13, 2020 11:09:19 GMT -6
Introduce some fuel into carb if it pops then you know you have a fuel delivery problem,, if it does pop then carbs probably gummed up and needs to be removed and thoroughly cleaned
Post by cyborg on Apr 13, 2020 11:07:43 GMT -6
Post by cyborg on Apr 13, 2020 11:05:20 GMT -6
Parts for scooters
Post by cyborg on Apr 13, 2020 11:03:55 GMT -6
Plugged up main jets
Post by cyborg on Apr 13, 2020 9:05:42 GMT -6
Mount is on the back of the panel
