Post by bad70nova68 on Dec 12, 2013 7:02:16 GMT -6
Well learned something new but then again everything is new to me on these things. Adjusted the valves to .005 and amazing this thing pers like a kitten. Thanks for your help. I am sure i will be back again.
Post by bad70nova68 on Dec 11, 2013 11:08:25 GMT -6
Thank you so much for your advice, i will adjust valves and if that dont work try your other suggestions, i thought it was a fuel problem like you described. Again thanks i will get back here in the morning after i try out these suggestions.
Post by bad70nova68 on Dec 11, 2013 8:06:53 GMT -6
Hello,
I am new to this scooter thing. This is what i know i was able to identify the scooter as a 50CC from the identification number that i found. Besides that i know nothing.
I was given this scooter as a friend couldnt get it running. I replaced the carb with a new one and redid all the wiring, removed everything but the basics no lights horn or anything.
Here is the problem, i have good fuel supply to the carb, it will start right up run about 10 seconds then die. I am able to restart in about 1 min and the same thing. I can start it and run with WOT, but still the same dies after about 10 - 15 Sec. Not sure where to go next.
Also i have the intake removed and noticed when i get it started i can place my hand over the intake it dies from being choked out and my hand is covered in fuel. Any suggestions where to start will be greatley appreciated. I have read adjust valves does this seem like a viable solution?
