Hello everyone,
I'm new to the forum and new to the scooter niche and I was hoping someone can help me out!
So recently, I purchased a non running 2004 VMOTO Milan scooter off of craigslist, it wasn't running and had no battery when I purchased it. I think it was in an accident since it was pretty busted up, all the plastics was cracked and front right side was missing a piece. The scooter was sitting outside for a while.
I took off the old air box since it was broken and dirty, currently it does not have an air box. Purchased a new air filter currently in transit. CARB currently does not have any kind of air filter on it.
It doesn't have both side plastics on at the moment.
Put a new spark plug
put a new battery
Changed the gasoline (The gas I put in was sitting in my garage for about 6 months. )
changed the 2 stroke oil
adjusted the idle screw
added some crab/fuel injector cleaner to the gas
even changed the transmission oil, took out old oil and put in 10w 30
Scooter runs now, and I can take it to full throttle when it's on the stand, without anyone sitting on it.
When it has a load on it or when i sit on it, it bogs down at full throttle after 40 kph. I weigh 180 lbs.
Also it does not seem to go past 40 KPH, or about 21 MPH, it bogs down even at half throttle, always around 40 kph no matter if I am going uphill or down hill.
also it is leaking engine oil from the right side from the bottom of the fan
it also leaks gasoline heavily 30 minutes after turning it off from the carb overflow tube.
Muffler also smokes and smells of something burning after turning it off
Vmoto milan and the tng Venice scooters are identical in engine design, and i think there are manufactured by the same scooter company in china. I don't have a milan manual, but I did find a 2004 TNG Venice manual.
On the TNG manual it says scooter is restricted to 2HP, derestrcted it has 4hp.
Does anyone know how to restricted it?
So I gave all available information and tried to be descriptive as possible; does anyone know why the scooter bogs down? Can someone please help me trouble shoot it?
Thank you
Read more:
49ccscoot.proboards.com/thread/10591/2004-vmoto-milan-scooter-throttle#ixzz3IcnTtwbV
