Post by gilmorej2 on Jun 9, 2015 19:57:47 GMT -6
Help, please. I have an 09 Metro that is basically dead. The battery is good but it does nothing when I turn the key on. No lights or electric start. Tried kick starting but get no spark. Please give me some ideas. Thanks
Post by cyborg on Jun 9, 2015 20:26:13 GMT -6
Check the main fuse
Post by jct842 on Jun 9, 2015 20:50:08 GMT -6
X2
Post by gilmorej2 on Jun 10, 2015 5:53:57 GMT -6
any idea on location? I located the relay but no fuses. Does sound like a good idea
Post by tvnacman on Jun 10, 2015 6:06:30 GMT -6
How did you check the battery?
Post by gilmorej2 on Jun 10, 2015 7:08:39 GMT -6
How did you check the battery? John i used a fluke multi meter and had it load tested at autozone. It registered 12.6 volts and didn't drop at all when I hit the start button. I did make sure kill switch was in the on position too haha
Post by gilmorej2 on Jun 10, 2015 7:09:47 GMT -6
The relay is making a clicking sound. Tried a new relay as well
Post by gilmorej2 on Jun 10, 2015 7:10:55 GMT -6
can't access anything goes
Post by cyborg on Jun 10, 2015 7:36:38 GMT -6
find the solenoid and cross up the two large poles with an old screw driver BRIEFLY,,,that should turn the starter over and quite possibly start the bike,,,and as i type i think the "relay" you say is clicking would probably be the solenoid ,,,and clicking is an indication that either the battery is not up to the task and is on it's way out or the terminals along the path of electricity are corroded or loose
Post by cyborg on Jun 10, 2015 7:37:34 GMT -6
you have to ask one of the admins if you can join anything goes,,,pm me
Post by gilmorej2 on Jun 10, 2015 10:04:12 GMT -6
find the solenoid and cross up the two large poles with an old screw driver BRIEFLY,,,that should turn the starter over and quite possibly start the bike,,,and as i type i think the "relay" you say is clicking would probably be the solenoid ,,,and clicking is an indication that either the battery is not up to the task and is on it's way out or the terminals along the path of electricity are corroded or loose its a small black electrical terminal with four male tabs coming off that plug into a socket. How do I pm you, cyborg?
Post by Alleyoop on Jun 10, 2015 10:21:51 GMT -6
This is the SOLENOID: Get a screw driver and touch both terminals it should spin your starter be prepared your motor may start. Alleyoop
Post by Alleyoop on Jun 10, 2015 10:27:23 GMT -6
To find it follow the thick red wire from the battery, the positive cable from the battery will be attached to one of the Solenoid terminals the other terminal on the Solenoid will go to the Starter.
Also if you hear clicking that is the Solenoid making that sound which usually means 1 of 2 things BAD SOLENOID or WEAK BATTERY. Also if it is clicking that also means your ignition is getting juice from the battery and anything else not working that should work with the key on is another problem. Your scoot MAY have a fuse box if so the fuse box's on the scoots control voltage to lights and other items on the scoot.
Alleyoop
Post by gilmorej2 on Jun 10, 2015 10:31:50 GMT -6
To find it follow the thick red wire from the battery, the positive cable from the battery will be attached to one of the Solenoid terminals the other terminal on the Solenoid will go to the Starter. Alleyoop thanks I will do that and repost.
Post by tvnacman on Jun 10, 2015 19:21:58 GMT -6
How did you check the battery? John i used a fluke multi meter and had it load tested at autozone. It registered 12.6 volts and didn't drop at all when I hit the start button. I did make sure kill switch was in the on position too haha I was not being a wise guy, #1 rule of troubleshooting take nothing for granted.
