Post by 860johnjohn on Mar 15, 2016 13:50:03 GMT -6
These are under the choke right next to the hose that supplies gas to the carb.What goes here ?
Post by Alleyoop on Mar 15, 2016 15:07:01 GMT -6
Those used to be for getting hot radiator fluid to the ENRICHER area to warm up the gas for better flow for COLD STARTS. But those are not used anymore and do not work as intended anyway SO nothing goes on them. Alleyoop
Post by 860johnjohn on Mar 15, 2016 16:17:19 GMT -6
Those used to be for getting hot radiator fluid to the ENRICHER area to warm up the gas for better flow for COLD STARTS. But those are not used anymore and do not work as intended anyway SO nothing goes on them. Alleyoop OK thanks
Post by 860johnjohn on Mar 16, 2016 12:30:43 GMT -6
Ok I put hoses just like in diagram (pic) but still wont stay on.
Post by Alleyoop on Mar 16, 2016 12:55:42 GMT -6
OK, take some pictures of the top and hoses NOT SO CLOSE so I can see more of the area and where the hoses are going to. Can you keep it running with a little bit of THROTTLE?
When it starts is the IDLE LOW OR HIGH? It could be the IDLE IS SET to low. When started cold the idle should be at least around 2000 rpms. Does the scooter have a tachometer ? Alleyoop
Post by 860johnjohn on Mar 17, 2016 21:22:05 GMT -6
OK, take some pictures of the top and hoses NOT SO CLOSE so I can see more of the area and where the hoses are going to. Can you keep it running with a little bit of THROTTLE? When it starts is the IDLE LOW OR HIGH? It could be the IDLE IS SET to low. When started cold the idle should be at least around 2000 rpms. Does the scooter have a tachometer ? Alleyoop Yes it has tachometer and it was at 2,000 for a very short time.I sent for the fuel pump today(just to be on safe side) The hoses coming out of fuel pump,1 goes to carb for gas and the other vaccum hose goes to intake manifold or canister?
Post by 860johnjohn on Mar 22, 2016 22:51:35 GMT -6
OK, take some pictures of the top and hoses NOT SO CLOSE so I can see more of the area and where the hoses are going to. Can you keep it running with a little bit of THROTTLE? When it starts is the IDLE LOW OR HIGH? It could be the IDLE IS SET to low. When started cold the idle should be at least around 2000 rpms. Does the scooter have a tachometer ? Alleyoop Yes it has tachometer and it was at 2,000 for a very short time.I sent for the fuel pump today(just to be on safe side) The hoses coming out of fuel pump,1 goes to carb for gas and the other vaccum hose goes to intake manifold or canister? Hey,is can you draw me a picture of the direction in which the hoses go coming out of the canister please.
Post by Alleyoop on Mar 23, 2016 7:51:17 GMT -6
