Post by keyztone on Mar 23, 2016 1:54:55 GMT -6
Ok.. I've capped the other 2 plugs off airbox..sealed airbox... Yet still..on center stand runs..but once on ground..open throttle but does not go...
Post by keyztone on Mar 23, 2016 3:31:21 GMT -6
There may be possibility the airbox isn't sealed still...gonna get good sealant once store opens..will try again... Actually got some thrust now..but not normal...
Post by Alleyoop on Mar 23, 2016 7:39:32 GMT -6
What do you mean when put on the center stand it runs but on the ground it does not go?
Does the motor make a BOG sound, does it rev up but it does not move? Need some detail of what it is doing so I can tell you what might be wrong. It could all be in the CVT bad belt bad clutch, bad weights etc..
If you can get a VIDEO of this that would help a lot Alleyoop
