Post by loydmstewart on Apr 28, 2016 16:56:30 GMT -6
You NEED AN AIR FILTER BRO!! Make sure the clamp holding it to the INTAKE IS TIGHT. But without an air filter you will have a hard time starting it. YOU can try and by holding your hand over the AIR INTAKE side with a couple fingers open to allow SOME air but not a lot of air. Alleyoop The fuel line on the carburetor goes on the top right want to make sure I did that right
Post by loydmstewart on Apr 28, 2016 16:59:45 GMT -6
Also going to need a new spark plug boot just don't know how to find them
Post by loydmstewart on Apr 28, 2016 17:22:51 GMT -6
Post by Alleyoop on Apr 28, 2016 18:08:09 GMT -6
Fuel line is good it goes on the middle connector on the right side. That air filter will work. Just unscrew the boot cap off your coil wire and take your spark plug and go to a autoparts store they will set you up with one. Then just screw it back onto the coil wire and you are set. Alleyoop
Post by loydmstewart on Apr 28, 2016 18:12:59 GMT -6
Fuel line is good it goes on the middle connector on the right side. That air filter will work. Just unscrew the boot cap off your coil wire and take your spark plug and go to a autoparts store they will set you up with one. Then just screw it back onto the coil wire and you are set. Alleyoop So I didn't completely screw everything up lol I have another spark plug boot but I'm not sure if it's any good then again I did test it and it was making a spark. Which I plan on also changing it might be part of the problem I was only getting small sparks from the spark plug
Post by loydmstewart on Apr 29, 2016 9:27:12 GMT -6
Good news is I have an extra spark plug boot so now all I need is a spark plug anyone know how much of a gap I'll need
Post by Alleyoop on Apr 29, 2016 11:36:08 GMT -6
.28
Post by loydmstewart on Apr 29, 2016 15:41:39 GMT -6
Is there away to tell if the CDI box is any good?
Post by Alleyoop on Apr 29, 2016 15:49:40 GMT -6
Do you know how to check for SPARK? If so if it sparks then your CDI is 99 percent ok unless it has a problem with the timing. Alleyoop
Post by loydmstewart on Apr 29, 2016 16:00:07 GMT -6
Do you know how to check for SPARK? If so if it sparks then your CDI is 99 percent ok unless it has a problem with the timing. Alleyoop Honestly it's sparking a little not a very powerful spark from the looks of it
Post by Alleyoop on Apr 29, 2016 16:25:44 GMT -6
Post by loydmstewart on Apr 29, 2016 17:02:12 GMT -6
Nothing came up but I did find this video This is pretty much the same thing mine is doing.I did what he does with the spark plug and got a very weak spark
Post by Alleyoop on Apr 29, 2016 17:09:51 GMT -6
Okey then get a new CDI Alleyoop
Post by loydmstewart on Apr 29, 2016 21:05:32 GMT -6
What kind of spark plug am I looking for I'm going tomorrow to hopefully tomorrow to get a new one
Post by Alleyoop on Apr 30, 2016 14:49:52 GMT -6
Take the plug that is in there to the autoparts store and they will give you an equivalent one to what is currently in there or one of the same. Alleyoop
