Post by lowry65 on Jun 7, 2016 3:50:14 GMT -6
I have this weird crunching noise coming from the rear wherl, rear brake works fine besides a sometimey squeak. It doesnt change with the use of the break, it sounds like a ratchet turning, its really annoying. Also some kind of burgundy dust is coming out of a hole next to the wheel on the "casing". You can see the burgundy dust coming from that slit or hole, it gets on the wheel, any help is appreciated!
Post by trashtruck12172 on Jun 7, 2016 6:04:46 GMT -6
is it burgundy dust or rust? check the clutch. something may have broken.
Post by lowry65 on Jun 7, 2016 7:35:03 GMT -6
is it burgundy dust or rust? check the clutch. something may have broken. I cant tell if its rust or burngundy dust, i would say burgundy dust, the clutch acts fine and the noise doesnt change, i only hear it when im rolling under 5mph or its on the center stand and i roll the wheel by hand, any other time the exhaust is too loud to hear or notice it ?
Post by trashtruck12172 on Jun 7, 2016 8:37:04 GMT -6
how old are the brake shoes? could be buildup and you may need to clean them up or new shoes.
Post by cyborg on Jun 7, 2016 11:47:39 GMT -6
Wheel bearing failure,,, I would suggest not riding any further,,, disassemble and replace both sides
