Post by floyd2133 on Oct 2, 2016 18:04:30 GMT -6
Starter is spinning but bendix is not enhancing fly wheel 2 vids 1 pix Video youtu.be/bbLjrNfRiZE youtu.be/WSp_d7jGrfg Pic a68.tinypic.com/nqsbqt.jpg a68.tinypic.com/2ebamib.jpg Any suggestions it worked this morning but now just spins Here is better video I'm trying to figure out do I need a bendix or starter. Also the bushing in this video on the belt side were the bendix tip goes is warped I can see it in video. 'My bendix doesn't sit up right and I have a hard time getting cvt on youtu.be/yyJNMIDIrHc Read more: 49ccscoot.proboards.com/thread/17172/starter-bendix-bad?page=1#ixzz4LyW4iXsr
Post by crwford on Oct 2, 2016 18:28:12 GMT -6
Lets get terms right first BENDIX is the name of a large company who produce large numbers of parts years ago, call starter drives for this strange reason every one seems to think the are called Bendix but they are started drives. Now using a power drill to test won't work, it works off a relay while starter spins relay throws out starter drive to engage crankshaft.
Post by floyd2133 on Oct 3, 2016 13:19:38 GMT -6
Yea but it seems like it's not even touching the starter it just sits and gears aren't touching
Post by jct842 on Oct 3, 2016 13:59:53 GMT -6
First of all you will notice that the drive end of the "starting system" is unsupported in your videos. It requires the case be on as there is a bushing in case. Second I would see that you have a fully charged "good" battery installed. You can check for bad grounds while at it. Those are decent starters but they need the full 12 while the starter is running and it sounds like yours is low.
Post by floyd2133 on Oct 3, 2016 15:05:46 GMT -6
I have a picture of the starter and bendix gears they aren't toUching. Any quick fix until I can get the bushing
Post by cyborg on Oct 6, 2016 7:32:27 GMT -6
I think there was a ring gear pressed on the end of that starter shaft spur,,,it may have cracked and fell off,,,did you find any metal on the bottom of the belt cover when you took it off?,,,,,,if you did that's where that gear or what's left of it was
Post by floyd2133 on Oct 6, 2016 8:05:18 GMT -6
What and we're is the ring gear. What is shaft spur? I looked at other starters online I don't see any pieces missing
Post by floyd2133 on Oct 6, 2016 8:06:14 GMT -6
Post by cyborg on Oct 7, 2016 9:30:10 GMT -6
I was mistaken ,, it's just the starter shaft teeth have been destroyed,,, looks like new starter time
Post by floyd2133 on Oct 7, 2016 10:13:50 GMT -6
Ok well my starter has come however I'm still waiting on bendix because teeth on bendix are warped should come today
Post by floyd2133 on Oct 7, 2016 10:18:21 GMT -6
New starter old bendix
Post by floyd2133 on Oct 8, 2016 8:41:36 GMT -6
I installed new battery ,bendix bushing, bendix and starter. However my voltage is dropping on crank . The starter isn't spinning any more however it makes contact with bendix n cranks but no turnover. I'm letting it trickle charge to 12.5 v I'm going to let it go to 13.5 then 14 hopefully this works. Any suggestions ? Video in next post
