Post by topgun024 on May 24, 2021 20:29:28 GMT -6
I have a 2006 Piaggo Fly 150. I took it out the other day and everything was completely fine, I stopped at a gas station and when I came out my scooter was dead. I hit the ignition switch and it did nothing, it didn't even attempt to turn over. Here is a list of things I have found thus far; -Electric start does nothing when starter button hit -Turn signals do not work -Tail light does not work -Brake light does not work -Headlight does work, and the high beam works as well -Horn does work -Oil light comes on when key is turned Here is a link to the wiring diagram, www.scooterwest.com/discover-learn/fly-150-wiring/I have replaced every fuse with brand new ones. I am not sure what exactly is going on. Please help!
Post by kz1000st on May 28, 2021 15:42:18 GMT -6
Go to www.modernvespa.com They can help you best with this. It sounds like a ground wire came undone or a dead battery.
