Post by rob00757 on Feb 6, 2012 14:49:49 GMT -6
My 2008 MC-54b, replaced thermostat, still runs hot but fan does go on. When it cools down, I take off the rediator cap and it sprays like a shook can of pop when opened. Could the radiator be plugged or why so much pressure built up? something is not right,,, any suggestions? Thinking of taking out the radiator and replacing it. thanks for any help
Post by bcgreatness on Feb 6, 2012 15:14:50 GMT -6
Does your scoot have a water pump? Maybe that's not working. I'm sure the pressure is just from over heating. If you have a water pump try taking off the out flow hose and see if its pumping out water.
Post by kz1000st on Feb 6, 2012 17:59:14 GMT -6
My 2008 MC-54b, replaced thermostat, still runs hot but fan does go on. When it cools down, I take off the rediator cap and it sprays like a shook can of pop when opened. Could the radiator be plugged or why so much pressure built up? something is not right,,, any suggestions? Thinking of taking out the radiator and replacing it. thanks for any help I would try no thermostat first. Even new thermostats can be bad. If it still sprays it might be still be air in the lines. Try squeezing hoses while it's cold and see if the level drops. BMW used to put bleeders on their cars heating systems to alleviate air bubbles.
Live To Ride / Ride To Live
Post by richardthescooter2 on Feb 8, 2012 9:01:10 GMT -6
I would put scoot on center stand, take cap off and let set for a few hours, then check it. sometime it takes a long time for those air bubbles to work themselves out.
