rpm meter
by: scooter62 - Sept 22, 2013 20:04:24 GMT -6
Post by scooter62 on Sept 22, 2013 20:04:24 GMT -6
Hi everyone I'm knew to this forum. I have a 86 Honda elite 150 I am working on and I am looking for advice on what tachometer people prefer to use to set the idle speed. 1,500 that it says in the book seems high and all I have is a old 4,6,or 8 cylinder car tach/dwell meter. Thanks, Scott
rpm meter
by: jct842 - Sept 22, 2013 20:06:11 GMT -6
Post by jct842 on Sept 22, 2013 20:06:11 GMT -6
just put on center stand and increase idle till rear wheel spins then back it off a tad till it almost stops or stops.....your done good as it gets
rpm meter
by: Alleyoop - Sept 22, 2013 20:11:54 GMT -6
Post by Alleyoop on Sept 22, 2013 20:11:54 GMT -6
The 150s like to idle around 1500-1800 that is where you are going to get the smoothest idle and not vibrate a lot. Alleyoop
rpm meter
by: redroush00 - Sept 28, 2013 16:54:12 GMT -6
Post by redroush00 on Sept 28, 2013 16:54:12 GMT -6
What if your wheel doesnt start to spin until 2500? Should it still be set that high?
My scoot rarely ever idles anyway except at a stoplight for a moment here and there. What are the dangers of a higher idle?
Even still at startup when choke is on its even higher still.
rpm meter
by: Alleyoop - Sept 28, 2013 17:37:55 GMT -6
Post by Alleyoop on Sept 28, 2013 17:37:55 GMT -6
WOW!! 2500 idle and higher when it first starts cold with the ENRICHER, you have it set WAY to high, May I ask WHY??
If would say the Clutch has stronger springs if at that idle the wheel is not turning. Alleyoop
-GONE-
rpm meter
by: FrankenMech - Oct 5, 2013 14:58:53 GMT -6
Post by FrankenMech on Oct 5, 2013 14:58:53 GMT -6
To use a standard Tach/dwell on a single cylinder 4-stroke engine just use the 4 cylinder TACH setting. Multiply the resulting reading by two. The 4-cylinder tach is expecting to see two spark impulses per engine revolution. Some engines like our scooters spark every revolution. The standard old-time automotive engine with a 1/2 speed distributor only fires a given cylinder every other revolution. A person just has to think about how many ignition pulses a given engine has per revolution. Take two aspirin and call the doctor if the headache persists.
