Post by kz1000st on Dec 25, 2013 18:42:38 GMT -6
Post by clonedrone on Dec 26, 2013 10:05:31 GMT -6
Interesting read. In the midst of my build I see the Valve springs as a real problem. I have three new sets from various vendors. Doesn't look like any thought or engineering is put into this area. For instance, All the springs I have have the inner spring coils going in the same direction as the outer Spring. Huh? Valve train #101 this setup translates bad ju ju Harmonics. the inner spring's all look like a Coil out of a Spiral Binder, A stiffer spring just increases my seat pressure, then I need to look at a different material for Valve seats. I have tried matching up to no avail with a high end PSI or PAC valve spring. I'll post what I end up doing along with my opening and set pressures and coil bind mesurements.
Post by kz1000st on Dec 26, 2013 10:32:23 GMT -6
Have you looked at titanium valve springs?
Post by clonedrone on Dec 26, 2013 12:38:02 GMT -6
Have you looked at titanium valve springs? No such thing. I ordered the as advertised Titanium Springs. Last time I checked Titanium is not magnetic, There just sprayed with a worthless coloring. Same quality of the inner spring coils going in the same direction as the outer spring, looks like something robbed out of a Spiral book binder. I will post spring specs for this spring as well.
Post by kz1000st on Dec 26, 2013 16:51:50 GMT -6
Well that stinks. I believed the ads. I have no reason to buy them but did have a set of heavy duty springs in my broken head. They're in the video.
kliff installed them.
Post by jct842 on Dec 26, 2013 17:00:15 GMT -6
For 150 I could see a 4 valve head using the 50cc valves or possibly a little larger ones. The lighter the weight the faster they can change direction. Same with springs.
Post by clonedrone on Dec 27, 2013 14:52:45 GMT -6
I think I have some Ti retainers that are CRN coated I can use. I'll do a REM Isotropic Finish to the Valve Springs along with some oil Pump parts and the Gear Set, I can do that in house. I haven't been able to match up any ti Valves with what I have in stock ie MX 150cc, 250cc and 450cc of all colors. Would cost me $116. each to make them, and I work here!
Post by cyborg on Jan 4, 2014 20:14:45 GMT -6
titanium ovate section wire is it for springs,,never had a failure in some pretty nutty builds
