Post by potwashman on Feb 9, 2014 7:58:10 GMT -6
Hi, I've just taken the front fairing off of my bike, Superbyke Powermax 50 4 stroke(just looking around) and bolted just next to the rectifier is a silver bracket with what looks like 30W39n stamped on it. When I took it off there is a spring that has been riveted to one end of the bracket, a ceramic disc around the spring(like you get on the end of a halogen linear bulb and heat resistant wire with a torpedo crimp on the end which then attaches to a green/white wire which goes into wiring loom and who knows where after that. Where the torpedo connections are it is quite dark as it looks like it has blown. it is 65mm long and 15mm wide. Any ideas what it is.
I'll try and take a pic and post but just got to go out now and take my son swimming.
Thanks
Post by jct842 on Feb 9, 2014 8:44:03 GMT -6
Is there a problem with the scooter? If it is running right don't fix it. Do take your picture though.
Post by potwashman on Feb 9, 2014 10:36:39 GMT -6
No problem that I am aware of but if there is something that wasn't working when I bought it (bike is 4yr old and I've had it 6mths)then I wouldn't be aware if something wasn't quite right. I'm sure it is there for a reason so don't see a valid reason not to fix it. I'll post pic then any help would be gladly received.
Post by tvnacman on Feb 9, 2014 11:31:47 GMT -6
could be an alarm ? or a relay/flasher . hard to tell without a picture .
Post by potwashman on Feb 9, 2014 11:49:43 GMT -6
Ive tried to upload couple of pics but the pics I've taken are 3mb each and it won't allow me to upload a pic bigger than 1mb. What is the workaround please.
Cheers
Post by tvnacman on Feb 9, 2014 11:54:44 GMT -6
open a photobucket account and upload the pics there then link it to the post .
photobucket.com no fee's at all .
Post by potwashman on Feb 9, 2014 13:31:07 GMT -6
see next post as didn't copy link
Post by potwashman on Feb 9, 2014 13:33:15 GMT -6
Hopefully this will take you to pic of the part. Cheers
Post by tvnacman on Feb 9, 2014 13:38:41 GMT -6
Post by Alleyoop on Feb 9, 2014 13:56:11 GMT -6
Hopefully this will take you to pic of the part. Cheers Sorry man I tried to fix the link so it would show up here and i messed it up( but it was a resistor for your lights i got it to work then tried to copy the a good link to show it here. Alleyoop
Post by potwashman on Feb 9, 2014 14:30:10 GMT -6
Thanks for the replies. Just before I came back to the Forum I was trawling through Ebay bike parts and saw one so ordered it. What does it do and what on my bike might not be working properly as a result of this. Cheers
Post by Alleyoop on Feb 9, 2014 15:01:11 GMT -6
It is the ballast resistor for your AC lighting on your scoot. When that resistor fails completely it may burn out light bulbs from to much voltage. Alleyoop
