new trikes
by: triker - Aug 15, 2018 15:59:39 GMT -6
Post by triker on Aug 15, 2018 15:59:39 GMT -6
Who can tell me who makes 49cc trikes besides Ice Bear?
Post by triker on Jun 21, 2018 18:10:35 GMT -6
I build lightweight tow-behind trailers with a 200 lb. capacity. If response to this thread warrants, I will send photos of a working prototype of what many have called a revolutionary idea (especially for trike owners). Email me ... rheshoot@yahoo.com
Electrical
by: triker - Sept 6, 2016 3:56:57 GMT -6
Post by triker on Sept 6, 2016 3:56:57 GMT -6
I found the problem shortly after I posted. The rear brake light switch was failing (intermittent contact). I found a replacement on-line for only a couple dollars. Figuring if one fails, the other can't be far behind, I ordered 2 left and 2 right. Considering that reliability of this part is critical, it's very cheaply made. I would have paid considerably more for a better-built part. Unless you have immediate access to a replacement, I suggest you get it before you need it!
Electrical
by: triker - Sept 5, 2016 9:01:40 GMT -6
Post by triker on Sept 5, 2016 9:01:40 GMT -6
With the ignition switch on, I'm getting power to the dash (fuel gauge, turn and horn) but not to the brake light from either lever. Consequently, no start switch. I can kick start it and the brake and running lights will begin to function. I think it's an intermittent short, I just can't locate it.
Batteries
by: triker - May 25, 2016 5:00:39 GMT -6
Post by triker on May 25, 2016 5:00:39 GMT -6
I could use the benefit of everyone's experience. Time to buy a new battery for my 49cc Icebear trike. I don't care about price as much as quality. Gell? Lead acid? Lithium? Could use all input before I pull out the plastic
Post by triker on Aug 16, 2015 6:10:47 GMT -6
Could someone tell me the plug gap for GY6 49cc with big bore kit. I'm trying to solve a missing/backfiring/running rich/lean issue. Thanks
Post by triker on Jul 4, 2015 9:55:56 GMT -6
Happy 4th Alleyoop! My variator mark after a speed run looks about like yours (about 1/4" from the edge). Do I want to get any closer than that? If not, what's the next step to get at least 10 mph more out of this low-end over-achiever? triker
Post by triker on Jul 3, 2015 11:00:07 GMT -6
After watching a few youtube vids, I got brave & disassembled the variator. I found flat spots on all 6 rollers. I re-assembled everything, marking the variator. After a speed run and disassembly, I found that the top of the belt rides about 1/4" from the top. First, I need to know what weight are the stock rollers in my 49cc icebear and where to buy a quality roller kit to dial in the top end. triker
Post by triker on Jun 21, 2015 12:20:20 GMT -6
Alleyoop OK After I do this, can I get back to you with the results (pics) and where to go from there?
Post by triker on Jun 21, 2015 12:11:08 GMT -6
I've had my 49cc Ice Bear trike for 14 months now, bought from a dealer here in Bradenton, FL. Finally, after 3 big bore kits, a blown engine, valve replacements and other issues (all under warranty), it seems to be dialed in pretty well. I sold my Hyundai Santa Fe as my work commute is only 1.5 miles. Even with all the initial problems, I'm really happy with it. As for the safety issue, obviously, if you get bumped on a 2-wheeler, you're going down. You've got a chance of staying upright in a minor collision on a trike. Besides, nothing better than the look on the cashier's face when you say "$3.00 on pump 5," and that's every 2 weeks! If your trike has a trailer hitch, I'll be happy to share the benefit of my experience with you and others on how to best utilize it.
Post by triker on Jun 21, 2015 11:40:01 GMT -6
Alleyoop Thanks for your response. Unfortunately, I don't know enough about the mechanics of the driveline to start exploratory surgery. What I think I understand is that there is an adjustment that can be made to trade some of that rpm for top end speed. Is there a video that addresses this issue? I'm hoping that with your help and others in this forum, I'll become more informed and capable of providing help along with requesting it. What I can provide right now for trike owners is my knowledge of utilizing the towing capability at an affordable price.
Post by triker on Jun 21, 2015 8:41:41 GMT -6
I'm a brand new member. I've got a 2014 (49cc) Ice Bear trike with a big bore kit (now 80cc). Currently, it will only manage 35mph @ 9000rpm! As it is now out of warranty, I'd like to know how involved (expensive) it would be to get 45mph out of it
