Post by fonz on Dec 22, 2015 6:38:26 GMT -6
Thanks for your help. I made a gasket for the valve cover and it worked and solve my problem. I am just wondering if a should have installed a second gasket. It seem to run well with the one gasket. No oil leaks.
Post by fonz on Dec 19, 2015 10:18:33 GMT -6
I installed an engine rebuilt kit on my 1985 Honda elite 150. I am having a problem adjusting the valves. When I place the valve cover onthe new head and torque it down it opens the valves and I get no compression. If I loosen the valve cover bolts a little the engine will run and I have compression. The adjusting bolts on the valve cover will not adjust far enough to relieve the pressure. Any help would be appreciated. please note the valves on this engine are adjusted externally on the side of the valve cover.
Post by fonz on Dec 13, 2015 6:28:21 GMT -6
Has anyone adjusted vales on a 1985 honda elite 150?
Post by fonz on Dec 11, 2015 6:06:52 GMT -6
Leaning to the new valves leaking. Anyway to check them.
Post by fonz on Dec 11, 2015 6:05:18 GMT -6
Rings are set correctly. Set timing by flywheel and cam. I am leaning to the new valves leaking.
Post by fonz on Dec 10, 2015 12:29:27 GMT -6
Install new top end for my honda scooter. Have no compression. I think I followed the maual properly. Have no idea what is wrong. Help!!
