Post by ryanlundy2 on Apr 22, 2016 17:13:01 GMT -6
Thanks. Yea the plug is new. I just ordered a new stator and flywheel hopefully that will do the trick. 30 volts was just turning over the engine. I have replaced the coil and cdi so if a new stator doesn't work I will be lost.
Post by ryanlundy2 on Apr 21, 2016 12:59:46 GMT -6
I was given a 2013 dykon scooter I think is a copy of the Tao Tao 50. Anyways this thing was in pieces and I'm slowly getting it together. Problem is o can't get spark. I have gone on to test voltage from the stator and am getting 30 volts AC. I replaced the cdi box and it didn't work. I also disconnect the safety switch black and white wire from the cdi box. Is this enough voltage from the stator? Is it bad? I'm stuck. Any help would be appreciated. Thanks
