Post by harry on Jun 26, 2016 20:12:22 GMT -6
I hate that crap,,,drill it and tap put a screw,,,this is silly now you should be riding,,,it's got to be the bowl not filling THANKS CYBORG! Runs great again! Did you know the float could be put in upside down?
Post by harry on Jun 25, 2016 19:58:57 GMT -6
Float stuck in the closed position ( up),, so no fuel getting to the carb,,, it's obviously a fuel issue now that you got it to pop with ether That is what I am thinking. The jet, needle and everything is clean and clear, but I am concerned that I could not hear the float rattle when I shook it after reassembly. Seems like I should be able to hear it move. Before, it may have been partially open allowing the bowl to fill after an hour - so it would start and run great for 30-40 seconds and not restart. Guess I will have to try a 3rd r&r. A big problem is that the drain port was never drilled out in the casting so I can't open and test it. Think I might do that this time.
Post by harry on Jun 25, 2016 17:57:32 GMT -6
I've also seen fuel hose separate and inside layer fold inward and shut off and /or restrict flow,,,I run clear motocross bike hose now on all my machines,,,one glance is all it takes to confirm flow Thanks I will check the hoses. Could the cold enrichment solenoid be a factor? It seemed to be functional when I tested it, but might be binding on the passageway. Ok, new clear fuel lines did not help, gas cap on/off didn't change anything. So I removed and cleaned the carb again, paying particular attention to the idle mixture passageway and the autochoke passages. Reassembled with my idle mixture at 2.5 turns open and it won't start. Removed the breather and shot some ether in and it ran for a couple of seconds, so I still have a fuel problem I presume. Put my hand over the carb inlet during cranking and it has good vacuum. I tried the fuel into the intake manifold test and the engine started, so it is a fuel problem of some sort. I expected the idle mixture screw to come to a point, but it is tapered to .022" dia at the tip. I presume that this is normal.
Post by harry on Jun 22, 2016 0:33:11 GMT -6
Post by harry on Jun 21, 2016 13:27:16 GMT -6
Gas tank too can be source of "junk" in fuel system. Fuel filter is micro-mesh style and was clean - before I cleaned it.
Post by harry on Jun 21, 2016 13:24:50 GMT -6
Re-clean the carb and replace the fuel filter and all fuel lines. Fuel lines can deteriorate from the inside and the bits of rubber can clog the jets, esp the idle jet. I can see how a clogged jet could keep it from starting, or idling smoothly, but it idles fine for about 40 seconds on this last try and then won't keep running on restart until a sufficient rest period. Perhaps the issue might be more related to float needle or enrichment solenoid?
Post by harry on Jun 21, 2016 11:33:05 GMT -6
Coil could be on the way out,,,,,next time it dies give the coil a decent rap with either a hard rubber/ wooden mallet see if it will lite up right away,,,but it does sound like that's the problem Thanks for the suggestion. I tried a new coil - same result. Other ideas?
Post by harry on Jun 18, 2016 19:51:13 GMT -6
I am trying to get a couple of scooters that sat for 10 years ready to sell for a cousin. This is a 125cc with 5 miles on it, so I am pretty sure it had fuel in it at one time. I flushed fresh fuel through the lines. It wouldn't start, so I removed and cleaned the carb. The idle mixture was originally about 1.5 turns open. The enrichment solenoid was working when I tested it while cleaning the carb. I put it back together and it started right up, warmed up normally and I rode it for about 10 miles. It ran great. I put about an oz of Gumout Carb Cleaner with a gallon of gas in the tank and let it sit while I worked on the 2nd scooter. Since then I have not been able to get it to warm up. It starts immediately and runs smooth for about 25 seconds and then starts to slow down and die. It may restart at that point for 5 seconds and then dies again. If it sits for a while, it will start back up fine for another 25 seconds...
There is fuel in the filter. I have tried bypassing the vacuum petcock, removing the tank cap, all with the same results. Fuel flows out of the line when I crank the engine so I think the petcock is fine. I drained the Gumout fuel and replaced with fresh 93 octane to see if that would help.
What am I missing??
Post by harry on Jun 18, 2016 11:42:55 GMT -6
I need to replace the stator on a 2005 157QMJ (150cc). Was hoping to order the puller and stator at the same time. Any way to tell how many poles it has without pulling the flywheel (CFW-125YX)? I tried looking through the hole and counting and best guess is 7, which doesn't help at all!
1) are 6 poles and 8 poles interchangeable with no other changes? 2) is 8 poles better than 6 poles?
Thanks for your help!
Post by harry on Jun 18, 2016 10:47:04 GMT -6
Thanks, for the tip crwford . I did a little searching and found that to be a frequent comment, which could explain why it was running well and then nothing. Stator VAC exciter output is way low. I presume that if the alarm was preventing the engine from starting, it wouldn't effect the exciter output.
Post by harry on Jun 17, 2016 14:21:40 GMT -6
Longbo 150 scooter was running on kick start with no battery. I got a battery, can't recall if I have started it off the battery, but I think I did. Now I am not getting any spark. After adding the battery, when I turn the key off or remove the key from the scooter, the alarm beeps 3 times after about 20 seconds. Is this an alarm condition that is keeping it from starting? It cranks fine but I am not getting any spark and have done the basic "no spark troubleshooting" - swapped coil, swapped CDI, checked resistance on the stator.
Used the remote fob to activate/deactivate the alarm, still does the 3 beeps thing. Anyone know what that means from the alarm? Thanks in advance for any help you can provide.
