Post by gman1234 on Jun 20, 2016 8:15:30 GMT -6
Thanks to everyone for your input I will take carb off at next opportunity.
Post by gman1234 on Jun 17, 2016 5:07:16 GMT -6
I hear adding additive to scooter messes thing up?
Post by gman1234 on Jun 16, 2016 15:51:41 GMT -6
Didn't use it but if plays up again then I will.
Post by gman1234 on Jun 15, 2016 13:57:08 GMT -6
Hi, brought some carb cleaner, thought I try starting it.fired and is running fine.
Post by gman1234 on Jun 14, 2016 14:55:03 GMT -6
Okay will do. And will do suggested other bits. Thanks will update when done.
Post by gman1234 on Jun 14, 2016 14:18:34 GMT -6
Thank you I will give it ago.
Post by gman1234 on Jun 14, 2016 13:59:48 GMT -6
Will I need to take all apart? Do I use carb cleaner? And what about fuel filter?
Thank you for your quick responses.
Post by gman1234 on Jun 14, 2016 13:49:46 GMT -6
Hi can I ask why it starts if the carb is blocked?
Post by gman1234 on Jun 14, 2016 12:55:17 GMT -6
Hi all, i'm after some help. I have a Yamaha Cygnus which I haven't use for over 2 years. I ve started to try get it back on the road, brought a new battery as old one was dead and wouldn't hold a charge. I manged to get the bike to fire up using kick-start and also on the button. The issue is that it runs for about 10-20 seconds the dies. The only way to keep it going is to give a little throttle but as soon as i let go the engine dies. So it wont idel.
Any Ideas appreciated
