Post by gatlin63 on Sept 2, 2019 8:21:01 GMT -6
The only solution would be to tap a set screw in to hold the bearing but before that i will still keep looking.
Thank You Rudy
Post by gatlin63 on Sept 2, 2019 8:19:25 GMT -6
If you look close at the picture one side is flat that's what the bearing rest against and the top rounded side is the fold over side to keep them in.
Post by gatlin63 on Sept 2, 2019 8:17:04 GMT -6
I had to machine the top of the link to press out the bearings. the bearing are pressed in then the bearing are swedged in with a fold over to keep them in. once you remove the fold over there is nothing to keep them in. I believe they are meant to be replaced and not rebuilt.
Post by gatlin63 on Sept 2, 2019 8:01:01 GMT -6
This is what I need to replace the bearings are not replaceable
Post by gatlin63 on Sept 2, 2019 7:59:40 GMT -6
Post by gatlin63 on Aug 30, 2019 11:10:59 GMT -6
I need to rebuild the front end of the df50tka trike all 4 of the steering links with the bearings in them are shot they look
like a twisted figure 8. I cant find anyone that sells them or what they are even called.
Any help would be a appreciated.
Thank You
Rudy
